Expand Grouped Layers by Default
18534
46
07-20-2023 08:25 AM
Status: Implemented
Labels (2)
lmurrayADOT
It would be helpful to have the option for grouped layers to be expanded by default within the Experience Builder Map Layers Widget.  Ideally, it would help to select which grouped layers are expanded and which are compressed by default.  However, even just having the ability to expand all grouped layers by default would make it easier for users to locate the layer they want to view.
46 Comments
LizaMarkey
Agree, this should be added - thank you!
RachelS
Another one looking for this functionality, sure experience builder should at the very least have the same basic functionality as Webapp builder.
Are there are plans to add this and if so, when?
LindseyStone
@Brian_McLeer I tried your suggested code in version 1.16, but when I enable the legend it also expands that.  I just want to enable the expansion of the layer list only, but still force a click on the legend to expand that.  Any ideas?
Brian_McLeer
@LindseyStone, this worked for me 1.15 DE but not 1.16 DE. I had to update the code, but there is loss of functionality in the Map Layers widget I am currently using.
  1. Map Actions do not work (increase transparency, decrease transparency, etc.)
  2. Legend does not show
I can give you the code that shows the group layers expanded by default and will expand/collapse group layers when you check the tick box on or off. However, with the lack of functionality of other functions it may take away more than it provides for you.
If Esri would allow to expand group layers by default and collapse/expand when a tick box is checked that would resolve most of my map layers widget issues.
WFCAdmin
Yes, please add this feature to Experience Builder! It was great having it in Web AppBuilder.
KevinBodrogi
Replying as another user who would like to see this functionality added. Thank you!
Brian_McLeer
This looks to be added in the February 2025 AGOL EB update.
TonghuiMing
This has been supported in the Map Layers widget since the recent Feb 2025 AGOL release, for both modes:
Geraldine
Great! When will it be available in ArcGIS Portal?
TonghuiMing
@Geraldine The feature will be included in portal 11.5 and later.
