Authentication widget
2091
06-16-2022 11:53 PM
Status: Open
henrilebon974
Hello ESRI,
Could you share the code of the widget below please. it is is the builder (top right). I think it could be pretty good to have a very good authentication widget in our Experience Builder Apps.
Thanks.
Tags (1)
5 Comments
DougLogsdon2
@henrilebon974,
After digging, I found this (undocumented) component:
import { UserProfile} from 'jimu-ui';
<UserProfile
  className="left esri-header-account-image"
  portalUrl={this.props.portalUrl}
  user={this.props.user}
  helpUrl={this.props.config.helpUrl || this.props.portalUrl} >
</UserProfile>
It will pull the current user, icon, etc from the active session and update through state changes.
For initial login, use the SessionManager:
onSigninClickHandler = () => {
  let sm = SessionManager.getInstance();
  sm.signIn();
Best of luck!
henrilebon974
Thank a lot Doug. I'm going to try that.
SaiBharadwaj
Hi. Can you share methodology how to implement this. Thanks
henrilebon974
Hello,
You can add it in a widget like this.
SaiBharadwaj
Thank you very much @henrilebon974 . I will try to implement this.
