Smart Editor does not use preset value from Group Filter
433
04-28-2022 11:46 AM
StevenBell2
We have a web application where a search parameter "Closure ID" is passed to the Group Filter. If a feature with that ID is present then you will see it in the map.  If not then the user should click on the Smart Edit widget and insert a Closure Point into the map with the ID number.
We have set the Group Filter
And set the Preset Attribute Action on the Smart widget
StevenBell2_2-1651171321190.pngStevenBell2_3-1651171350002.pngStevenBell2_4-1651171394087.png
But the field is never populated with the preset value.
I have read it could be related to feature template, but I have recreated the template multiple times, republished the service many times, and copied the data as hosted and referenced it.
Does anyone know what I am missing?
