Sharing 3D Tile Cache Data Store: Problem Submitting tile caching job
1335
6
07-29-2022 09:16 AM
JeffFennellUSAFennell
New Contributor III
Setup a Tile Cache Data Store through Azure Cloudbuilder. Installation succeeded with no errors.
When trying to share a 3D layer from ArcGIS Pro, I get the following error: Problem Submitting tile caching job
On the log the last lines are:
  • Status: InProgress StatusMessage: Initializing scene caching process on the server
  • Status: Failed StatusMessage: Problem submitting tile caching job
MatthewThomas2
Hi Jeff, try logging into ArcGIS Server Manager and under Services > System, try restarting the CachingTools service and the PublishingTools service. If that doesn't fix it, try logging into the ArcGIS Server Admin endpoint, and go to Services > System, and open each of these 4 services and restart them all: CachingTools, CachingToolsEx, PublishingTools, PublishingToolsEx. Then try publishing again.
New Contributor III
I didn't see CachingToolsEx or PublishingToolsEx, but I saw CachingTools10x & PublishingTools10x (picture attached). I restarted all the services and tried it again and got the following error:
Error - ERROR 160213: A networking error occurred.
Error - Failed to execute (Manage Scene Cache).
Informative - Failed at Monday, August 1, 2022 10:21:25 AM (Elapsed Time: 12.35 seconds)
Error - Failed.
MatthewThomas2
Jeff, what version of ArcGIS Enterprise and ArcGIS Pro are you using?
New Contributor III
Enterprise is 10.9.1 & Pro is 2.9.0
I did see the Feature Layer & Scene Layer were uploaded, but when I try to add it to a scene it says:
"Scene service is missing root node."
New Contributor III
Hey Matthew,
Just curious if you had any ideas about how to solve this? We still haven't figured it out
New Contributor III
Solution: We needed to open up inbound ports 29080 & 29081 on the tile cache machine.
