Hi!
I am trying to create a feature service webhook and I use ArcGIS Enterprise 11.0. I have read that webhooks are in beta version at 11.0, but still, I want to make sure that I am doing everything OK.
When creating the webhook I get the following error: "Error: Feature Service must have Editing and Change Tracking enabled without Sync".
However, checking the feature service properties in the Portal, it looks to me that my setting are OK. I attach screenshot of my settings.
Anybody could advise on this?
Unfortunately in ArcGIS Enterprise 11.0 when you check the "Keep track of who edited the data" option there, it does not actually update the FeatureService with the required setting. You'll need to manually go into the Rest Admin for the service and update the capabilities to include ChangeTracking using the UpdateDefinition endpoint.
eg.
eg.
Hi @bogdanpalade2 - You're attempting to get to updateDefinition from the Server Admin - updateDefinition is in the REST Services Admin, its a very subtle difference.
Your URL will look something like
SERVER.COM/server/rest/admin/services/Hosted/MyFeatureServiceName/FeatureServer/updateDefinition
Thank you very much Kevin! This was the solution!
Hi @bogdanpalade2 , @KevinHibma
I'm also trying to create webhooks in Enterprise11.1.
I was wondering if your data is being submitted through Survey123?
It seems Sync must be enabled for this but then 'TrackChanges' can't be on, so defeats the whole purpose if Sync is disabled users can't submit data and there are no changes to be tracked!
Sync is not currently supported with ArcGIS Enterprise Hosted Feature Service webhooks. We have an enhancement to add support. However, adding this level of support comes with some technical challenges, as such, I can't offer any sort of timeframe of when/if we'll achieve this.
Hi @KevinHibma,
So I understand that it is currently impossible with ArcGIS Enteprise 11.1 to use the "When a record is updated in a feature layer" trigger of the ArcGIS Enterprise Connector and then fetch for updates with the "Fetch updates, changes, or deletions from feature layer" action when using Survey123?
The Survey123 webhooks work a bit differently than the Feature Service webhooks in what payload is returned. Without looking at the actual differences, I'd guess that no, you cannot use the Fetch updates from the S123 webhook.
In theory, the S123 and FS webhooks overlap: Survey: "New Survey" = Feature Service: "FeaturesCreated". Survey:"Survey Updated" = Feature Service: FeaturesUpdated. It's just a feature service behind the Survey right? So you could probably create a FS webhook yourself on the service, listening for FeaturesUpdated, and then use the Fetch connector in Power Automate.
I keep having the following error when trying to create a webhook on the Survey Feature Service : "Error: Feature Service must have Editing and Change Tracking enabled without Sync". I think, by design, it's impossible to create a webhook on a Survey feature service because Portal doesn't seem to allow enabling Tracking changes for Survey's Feature Services.
Suppose we create an internal ExB application in which we would like to start a power automate flow when someone modify a value of a field (ex : a status - Submitted, Working, Done) and send an email when the status is Done. Is there a way to do this? The only thing we were able to do is use a Survey123 webhook with Send Edits enabled with a custom connector. But people need to be part of a shared update group and edit the form in Survey Web. Only editing in the form activates the Webhook, not in the datagrid. We think this solution requires too much permissions (member of a shared update group) and is not as convenient as using an Hosted Feature Layer View in a map or in an ExB application.
