Failed to Register Oracle 19C Geodatabase into ArcGIS Enterprise
1372
12-07-2020 11:38 PM
SainsDSI
I am currently setting up ArcGIS Enterprise Infrastructure and I am stuck at registering the database which is in Oracle 19C. It gives me the error;
"The connection property set was missing a required property or the property value was unrecognized. Unspecified error"
Anyone encountered this problem before?
George_Thompson
Esri Notable Contributor
What version of ArcGIS Enterprise is being used?
What is the version of the Enterprise Geodatabase?
Do you have any other geodatabases registered successfully?
Do you have the 64 bit Oracle client installed on the Server machine within Enterprise?
--- George T.
ThomasJones1
Hello @SainsDSI
Just to follow up on Georges questions. If you are using ArcGIS Server 10.6.x or 10.7.x you need to apply the following patch to register the Oracle 19C database with ArcGIS Server.
Oracle database requirements for ArcGIS 10.6.x ArcGIS Pro 2.1 and 2.2
ArcGIS (Desktop, Engine, Server) Support for Oracle 19c Patch
Thomas
Victor_Estevez
hello @ThomasJones1
This patch works with arcgis server 10.6 or it's only for 10.6.1?
Thanks!
vnixon
I am also very curious if 10.6.x includes 10.6 or if it only includes 10.6.1, 10.6.2, etc.
Thanks!
