Create an automated mapping service
1964
05-08-2022 03:35 AM
MichaelBell
We've got ArcGIS Enterprise and ArcGIS Server is installed. Now, what we're after doing is something that can accomplish the following:
1 - user enters a parameter value (eg "123") in a textbox on a html page. Presses submit.
2 - a pdf map (using a custom layout) is generated. The pdf shows only the features from a feature class that contain the parameter's value (eg "BlockID=123") and zoomed to those features
Edit - this should be able to be done without the user interacting with any map at all. So they can just press a button on any old html webpage and the pdf is generated.
I've managed this locally on my machine, simply using ArcGIS Pro and some Python notebooks, but am struggling figuring out how to get it working online and the documents are a bit of a maze to navigate. If nothing comes of this, I'll contact esri directly.
Thanks!
Scott_Tansley
MVP Regular Contributor
Hi,  I'm not aware of anything straight from the box, but there is a business partner that has a product that may help you:
Feature Data Reports for ArcGIS Online - dymaptic
I'm sure there are other solutions, but I tried this for something similar and was impressed.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
TanuHoque
@MichaelBell
Since you have already figured it out how to do it in Pro - I assume using arcpy, all you need to do is to share that out as a geoprocessing service. And you should be good.
nita14
Hi Michael,
The tool (Python + ArcPy) needs to authored in ArcGIS Pro. Once it runs with success, you need to proceed with a publishing process. If you are willing to share sample datasets and your script, I can help you out. Definitely, it is feasible.
Bests,
Adam
MichaelBell
Thanks all for your help, this one is taking a back seat at the moment until I get ArcServer configured correctly.
