ArcGIS Powershell DSC 3.3.2 module does not uninstall WebAdaptor
947
07-12-2022 11:02 AM
DianaBenedict1
I am using the latest version of ESRI ArcGIS Powershell DSC modules 3.3.2. I am attempting to upgrade from 10.8.1 to 10.9.1 our Federated ArcGIS Server. The inplace upgrade of the ArcGIS Server software works. After the ArcGIS Powershell DSC has successfully ran the upgrade it is supposed to uinstall the existing ArcGIS WebAdaptor version 10.8.1 and then install the new 10.9.1. However, I noticed, after running the cmdlet that the webadaptor is not uninstalled and therefore fails when attempting to install the new 10.9.1 version.
I have manually uninstalled the webadaptor 10.8.1 and then invoked the cmdlet and that seemed to work -  it continues where it left off and installs the 10.9.1 and finishes the configuration.  Have others using the 3.3.2 ArcGIS modules encountered the same issue? I did not have this issue with previous versions of the ArcGIS modules.
Diana
