I am using Ansible to deploy and configure my ArcGIS Server instances. To configure the installation I use the REST API. Once the server is configured I want to deploy my map services. Since the data is in an Oracle EGDB I need to register this one (Data Stores). What I am missing at the moment is a description of the Enterprise GDB connection strings.
I based my code on this project : GitHub - Esri/ops-server-config: Operations Server Configuration scripts
_postgres_db_conn_template_str = "SERVER=serverReplaceStr;" + \
"INSTANCE=sde:postgresql:serverReplaceStr;DBCLIENT=postgresql;" + \
"DB_CONNECTION_PROPERTIES=serverReplaceStr;DATABASE=dbReplaceStr;" + \
"USER=userReplaceStr;PASSWORD=" + \
"passwordReplaceStr;VERSION=sde.DEFAULT;AUTHENTICATION_MODE=DBMS"
In my case I use Oracle, so is it ok to change the connection to like this:
_oracle_db_conn_template_str = "SERVER=serverReplaceStr;" + \
"INSTANCE=sde:oracle:serverReplaceStr;DBCLIENT=oracle;" + \
where: serverReplaceStr is the connection name is the tnsnames.ora file.
I took an old code (seems to use the < 10.1 syntax) from a colleague the does the same thing with arcpy. I created a SDE connection file and uploaded it manually:
The connection string looked like this (this was an Oracle 11g instance) (ArcGIS Server Manager):
"PASSWORD=****;SERVER=sde:oracle11g:TEST_DB;" + \
"INSTANCE=sde:oracle$sde:oracle11g:TEST_DB$SDE;" + \
"DBCLIENT=oracle;DB_CONNECTION_PROPERTIES=TEST_DB;" + \
"PROJECT_INSTANCE=sde;USER=TEST;VERSION=SDE.DEFAULT;AUTHENTICATION_MODE=DBMS"
Why Is $SDE added to the INSTANCE name? The prefix sde:oracle11g seems not needed anymore.
Manfred
