Configure HTTPS only, for site - Privacy error.
1197
12-20-2016 10:19 AM
SandyL
I had installed ArcGIS Server 10.4 and had selected 'Configure HTTPS Only for your site' and receive privacy error. Previously it was set to http and I was able to connect to ArcGIS Server using port 6080. After setting it to https only, and while trying to access HTTPS URL of ArcGIS Server, I receive Privacy error. Any help appreciated.
 Enterprise GIS arcgis enterprise dlaw-esristaff
Tags (1)
AdamZiegler1
Hi Sandy - You are receiving this error because you need to install a security certificate to make the site trusted. There are several tutorials in the help to guide you. If this is a production site, I would suggest getting a cert through a certificate authority (CA).
Configuring HTTPS only using the default self-signed certificate—ArcGIS Server Administration (Linux...
Hope this helps.
-Adam Z
AdamZiegler1
Hope this helps.
-Adam Z
