ArcGIS Enterprise Site - Remove Sign In Option
4275
6
07-14-2021 06:35 AM
by Anonymous User
Not applicable
Do you know of a way to either disable/remove or hide the sign in option at ArcGIS Enterprise sites in the upper right corner of the page? My users have a habit of getting confused by the sign in option, which the shouldn't use.
Cheers,
Andreas
Nukissiorfiit
ReeseFacendini
Esri Alum
In order to disable the sign in option, toggle the Global Navigation setting to off, under Settings -> Interactions
by Anonymous User
Not applicable
Hi @ReeseFacendini
I can't seem to find that setting on my site in my portal:
Maybe it's an old version that I am working with.
ReeseFacendini
Esri Alum
What version of Enterprise are you working with?  Also, do you own the site or are you only an editor?
by Anonymous User
Not applicable
I am on 10.71 and should be the owner of the site.
ReeseFacendini
Esri Alum
@Anonymous User I checked with a 10.7.1 Enterprise Sites page, and you are correct that it's not available.  I believe that functionality was added starting at 10.8
by Anonymous User
Not applicable
All right, I suspected so, thanks anyways @ReeseFacendini
