Do you know of a way to either disable/remove or hide the sign in option at ArcGIS Enterprise sites in the upper right corner of the page? My users have a habit of getting confused by the sign in option, which the shouldn't use.
Cheers,
Andreas
Nukissiorfiit
In order to disable the sign in option, toggle the Global Navigation setting to off, under Settings -> Interactions
I can't seem to find that setting on my site in my portal:
Maybe it's an old version that I am working with.
What version of Enterprise are you working with? Also, do you own the site or are you only an editor?
I am on 10.71 and should be the owner of the site.
@Anonymous User I checked with a 10.7.1 Enterprise Sites page, and you are correct that it's not available. I believe that functionality was added starting at 10.8
All right, I suspected so, thanks anyways @ReeseFacendini
