A way / tool to count the number of allocated max\min instances for all published services
7278
33
04-07-2017 10:12 AM
rawansaleh1
I couldn’t figure out if there are a tool or a way to count the number of allocated max\min instances for all published services. See below
Best Regards,
Rawan
rawansaleh1
Dear Avinash,
Tanks a lot for your effort, sorry I have no idea about coding.
But this python is amazing, thanks again for your effort.
Best,
Rawan
rawansaleh1
Dear Aviniesh,
The py file doesn’t catch the services published in the system folder (attached), what might be issue here?
Best,
Rawan
by Anonymous User
Not applicable
Hi Rawan Saleh,
Need to check
But in my new project don't get enough time to do testing and rectifying.
update you soon.
rawansaleh1
 Dear Avinash,
I could manage to do this, kindly find the below it works fine with me.
# Reads the following properties from services and writes them to a comma-delimited file:
# ServiceName, Folder, Type, Status, Min Instances, Max Instances, KML,
# WMS, Max Records, Cluster, Cache Directory, Jobs Directory, Output Directory
# For HTTP calls
import httplib, urllib, json
# For system tools
import sys
# For reading passwords without echoing
import getpass
def main(argv=None):
# Ask for admin/publisher user name and password
 username = raw_input("Enter user name: ")
 password = getpass.getpass("Enter password: ")
# Ask for server name & port
 serverName = raw_input("Enter server name: ")
 serverPort = 6080
# Get the location and the name of the file to be created
 resultFile = raw_input("Output File: ")
# Get a token
 token = getToken(username, password, serverName, serverPort)
# Get the root info
 serverURL = "/arcgis/admin/services/"
# This request only needs the token and the response formatting parameter
 params = urllib.urlencode({'token': token, 'f': 'json'})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
# Connect to URL and post parameters
 httpConn = httplib.HTTPConnection(serverName, serverPort)
 httpConn.request("POST", serverURL, params, headers)
# Read response
 response = httpConn.getresponse()
 if (response.status != 200):
 httpConn.close()
 print "Could not read folder information."
 return
 else:
 data = response.read()
 # Check that data returned is not an error object
 if not assertJsonSuccess(data):
 print "Error when reading server information. " + str(data)
 return
 else:
 print "Processed server information successfully. Now processing folders..."
# Deserialize response into Python object
 dataObj = json.loads(data)
 httpConn.close()
#Store the Folders in a list to loop on
 folders = dataObj["folders"]
#Remove the System and Utilities folders
 folders.remove("System")
 # folders.remove("Utilities")
#Add an entry for the root folder
 folders.append("")
 folders.append("System")
#Create the summary file of services
 serviceResultFile = open(resultFile,'w')
 serviceResultFile.write("ServiceName,Folder,Type,Status,Min Instances,Max Instances,FeatureService,kml,wms,Max Records,Cluster,Cache Directory,Jobs Directory,Output Directory" + "\n")
#Loop on the found folders and discover the services and write the service information
 for folder in folders:
 # Determine if the loop is working on the root folder or not
 if folder != "":
 folder += "/"
# Build the URL for the current folder
 folderURL = "/arcgis/admin/services/" + folder
 httpConn.request("POST", folderURL, params, headers)
# Read response
 httpConn.close()
 return
 else:
 print "Error when reading folder information. " + str(data)
 else:
 print "Processed folder information successfully. Now processing services..."
 httpConn.close()
# Loop through each service in the folder
 for item in dataObj['services']:
if item["type"] == "GeometryServer":# and folder == "":
 # Build the Service URL
 if folder:
 sUrl = "/arcgis/admin/services/%s%s.%s" %(folder,item["serviceName"], item["type"])
 statusUrl = "/arcgis/admin/services/%s%s.%s/status" %(folder,item["serviceName"], item["type"])
 else:
 sUrl = "/arcgis/admin/services/%s.%s" %(item["serviceName"], item["type"])
 statusUrl = "/arcgis/admin/services/%s.%s/status" %(item["serviceName"], item["type"])
 httpConn.request("POST", sUrl, params, headers)
 # Get the response
 servResponse = httpConn.getresponse()
 readData = servResponse.read()
 jsonOBJ = json.loads(readData)
# Build the Service URL to test the running status
# Submit the request to the server
 httpConn.request("POST", statusUrl, params, headers)
 servStatusResponse = httpConn.getresponse()
# Obtain the data from the response
 readData = servStatusResponse.read()
 jsonOBJStatus = json.loads(readData)
# Build the line to write to the output file
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + "NA" +"\n"
# Write the results to the file
 serviceResultFile.write(ln)
httpConn.close()
 elif item["type"] == "SearchServer":# and folder == "":
 if folder:
 else:
# Get the response
# Get the response
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + str(jsonOBJ["properties"]["jobsDirectory"]) + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
 httpConn.close()
 elif item["type"] == "ImageServer":
 if folder:
 else:
# Get the response
 if folder:
 else:
# Get the response
# Extract the WMS properties from the response
 wmsProps = [imageWMS for imageWMS in jsonOBJ["extensions"] if imageWMS["typeName"] == 'WMSServer']#.items()[0][1] == 'WMSServer']
if len(wmsProps) > 0:
 wmsStatus = str(wmsProps[0]["enabled"])
 else:
 wmsStatus = "NA"
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + wmsStatus +"," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + str(jsonOBJ["properties"]["cacheDir"]) + "," + "NA," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
 httpConn.close()
 elif item["type"] == "GlobeServer":
 if folder:
 else:
# Get the response
#Build the Service URL to test the running status
 if folder:
 else:
# Get the response
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + str(jsonOBJ["properties"]["cacheDir"]) + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
httpConn.close()
 elif item["type"] == "GPServer":
 if folder:
 else:
# Get the response
 if folder:
 else:
# Get the response
 httpConn.close()
 elif item["type"] == "GeocodeServer":
 if folder:
 else:
# Get the response
if folder:
 else:
# Get the response
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
 httpConn.close()
 elif item["type"] == "GeoDataServer":
 if folder:
 else:
# Get the response
if folder:
 else:
# Get the response
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
 httpConn.close()
 elif item["type"] == "MapServer":
 if folder:
 else:
# Get the response
 if folder:
 else:
# Get the response
# Check for Map Cache
 isCached = jsonOBJ["properties"]["isCached"]
 if isCached == "true":
 cacheDir = str(jsonOBJ["properties"]["cacheDir"])
 else:
 cacheDir = jsonOBJ["properties"]["isCached"]
if len(jsonOBJ["extensions"]) == 0:
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "FeatServHolder" + "," + "Disabled" + "," + "Disabled" +"," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + cacheDir + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
 else:
 # Extract the KML properties from the response
 kmlProps = [mapKML for mapKML in jsonOBJ["extensions"] if mapKML["typeName"] == 'KmlServer']#.items()[0][1] == 'KmlServer']
 wmsProps = [mapWMS for mapWMS in jsonOBJ["extensions"] if mapWMS["typeName"] == 'WMSServer']#.items()[0][1] == 'WMSServer']
# Extract the FeatureService properties from the response
 featServProps = [featServ for featServ in jsonOBJ["extensions"] if featServ["typeName"] == 'FeatureServer']#.items()[0][1] == 'FeatureServer']
if len(featServProps) > 0:
 featureStatus = str(featServProps[0]["enabled"])
 else:
 featureStatus = "NA"
if len(kmlProps) > 0:
 kmlStatus = str(kmlProps[0]["enabled"])
 else:
 kmlStatus = "NA"
 else:
 wmsStatus = "NA"
 ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + featureStatus + "," + kmlStatus + "," + wmsStatus +"," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + cacheDir + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
 else:
 # Close the connection to the current service
 httpConn.close()
 # Close the file
 serviceResultFile.close()
def getToken(username, password, serverName, serverPort):
 # Token URL is typically http://server[:port]/arcgis/admin/generateToken
 tokenURL = "/arcgis/admin/generateToken"
 params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
 httpConn.request("POST", tokenURL, params, headers)
 # Read response
 httpConn.close()
 print "Error while fetching tokens from admin URL. Please check the URL and try again."
 return
 else:
 httpConn.close()
 return
 # Extract the token from it
 token = json.loads(data)
 return token['token']
# A function that checks that the input JSON object
# is not an error object.
def assertJsonSuccess(data):
 obj = json.loads(data)
 if 'status' in obj and obj['status'] == "error":
 print "Error: JSON object returns an error. " + str(obj)
 return False
 else:
 return True
if __name__ == "__main__":
 sys.exit(main(sys.argv[1:]))
Best,
Rawan
JonathanQuinn
Esri Notable Contributor
It's possible by creating a token, getting the list of services, looping through each service, grabbing the min/max instances, adding them to a counter, and getting the list of folders, getting the list of services in each folder, looping through each service, and grabbing the min/max instances, and adding them to a counter as well:
import urllib2, urllib, json, ssl
#Avoids self signed certificate errors
ssl._create_default_https_context = ssl._create_unverified_context
baseURL = 'https://<machine>.<domain>.com:6443/arcgis'
psaUsername = '<username>'
psaPassword = '<password>'
#Function to open URLS
def openURL(url,params):
    encodedParams = urllib.urlencode(params)
    response = urllib2.urlopen(url,encodedParams).read()
    jsonResponse = json.loads(response)
    return jsonResponse
serverAdminURL = "{0}/admin".format(baseURL)
tokenURL = '{0}/tokens/generateToken'.format(baseURL)
#Generates an admin token
tokenParams = dict(username=psaUsername,password=psaPassword,client='requestip',f='json')
token = openURL(tokenURL,tokenParams)['token']
rootServicesURL = "{0}/services".format(serverAdminURL)
adminParams = dict(token=token,f='json')
#Starts the min/max counters
totalMinInstances = 0
totalMaxInstances = 0
#Gets services in the root directory
rootServices = openURL(rootServicesURL,adminParams)['services']
#Loops through services
for service in rootServices:
    serviceName = service['serviceName']
    serviceType = service['type']
    serviceURL = "{0}/{1}.{2}".format(rootServicesURL,serviceName,serviceType)
    #Gets service information
    serviceInfo = openURL(serviceURL,adminParams)
    minInstances = serviceInfo['minInstancesPerNode']
    maxInstances = serviceInfo['maxInstancesPerNode']
    #Adds min/max instances to counters
    totalMinInstances += minInstances
    totalMaxInstances += maxInstances
    print("Service {0} is configured with {1} min instances and {2} max instances.".format(serviceName,minInstances, maxInstances))
#Gets folders
rootFolders = openURL(rootServicesURL,adminParams)['folders']
for folder in rootFolders:
    #Optionally go through System and Utilities folders, (you'll need to uncomment the line and fix the indentation)
    #if not folder in ['System','Utilities']:
    folderURL = "{0}/{1}".format(rootServicesURL,folder)
    #Gets services in folders
    servicesInFolders = openURL(folderURL,adminParams)['services']
    #Loops through services in folders
    for service in servicesInFolders:
        serviceURL = "{0}/{1}/{2}.{3}".format(rootServicesURL,folder,serviceName,serviceType)
        print("Service {0}/{1} is configured with {2} min instances and {3} max instances.".format(folder, serviceName,minInstances, maxInstances))
#Returns min/max instances.
print("Total minimum instances: {0}".format(totalMinInstances))
print("Total maximum instances: {0}".format(totalMaxInstances))‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
rawansaleh1
Dear Jonathan,
Thanks for your answer,
 I tried to add the previous code in a python, but when I tried to open it it fails to work.
I couldn’t figure out what is the reason for that.
What do you think?
Best,
Rawan
JonathanQuinn
Without any information about the error, it's impossible to provide assistance.
rawansaleh1
Dear Jonathan,
Many thanks for your answer.
Kindly find the following screenshots.
Best,
Rawan
JonathanQuinn
The variables on line 6, 7, and 8 are simply place holders.  Replace them with the appropriate information for your Server.
rawansaleh1
Dear Jonathan,
I got the same error even though I entered the specific variable
Best,
Rawan
