A way / tool to count the number of allocated max\min instances for all published services
6712
33
04-07-2017 10:12 AM
rawansaleh1
I couldn’t figure out if there are a tool or a way to count the number of allocated max\min instances for all published services. See below
Best Regards,
Rawan
JonathanQuinn
Esri Notable Contributor
If you can reach what you entered for the baseURL in a browser on the machine you're running the script, there shouldn't be a reason why you see the getaddrinfo error in Python.  That error simply means the host can't be found.
by Anonymous User
Not applicable
Hi Rawan,
I am sharing new script after making some work in @Jonathan Quinn script.
Find the out put like
Total minimum instances: ****---count
Total maximum instances: ***--count
https://community.esri.com/docs/DOC-9922/edit?draftID=328241
Jonathan_Avinash.zip
by Anonymous User
Not applicable
@Rawan
Are you able to execute this?
rawansaleh1
Dear Avinash,
Thanks for your effort, actually I couldn’t access the above link. Attached
What might be the issue here?
Best,
Rawan
