I couldn’t figure out if there are a tool or a way to count the number of allocated max\min instances for all published services. See below
Best Regards,
Rawan
Dear Avinash,
Tanks a lot for your effort, sorry I have no idea about coding.
But this python is amazing, thanks again for your effort.
Best,
Rawan
Dear Aviniesh,
The py file doesn’t catch the services published in the system folder (attached), what might be issue here?
Best,
Rawan
Hi Rawan Saleh,
Need to check
But in my new project don't get enough time to do testing and rectifying.
update you soon.
Dear Avinash,
I could manage to do this, kindly find the below it works fine with me.
# Reads the following properties from services and writes them to a comma-delimited file:
# ServiceName, Folder, Type, Status, Min Instances, Max Instances, KML,
# WMS, Max Records, Cluster, Cache Directory, Jobs Directory, Output Directory
# For HTTP calls
import httplib, urllib, json
# For system tools
import sys
# For reading passwords without echoing
import getpass
def main(argv=None):
# Ask for admin/publisher user name and password
username = raw_input("Enter user name: ")
password = getpass.getpass("Enter password: ")
# Ask for server name & port
serverName = raw_input("Enter server name: ")
serverPort = 6080
# Get the location and the name of the file to be created
resultFile = raw_input("Output File: ")
# Get a token
token = getToken(username, password, serverName, serverPort)
# Get the root info
serverURL = "/arcgis/admin/services/"
# This request only needs the token and the response formatting parameter
params = urllib.urlencode({'token': token, 'f': 'json'})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
# Connect to URL and post parameters
httpConn = httplib.HTTPConnection(serverName, serverPort)
httpConn.request("POST", serverURL, params, headers)
# Read response
response = httpConn.getresponse()
if (response.status != 200):
httpConn.close()
print "Could not read folder information."
return
else:
data = response.read()
# Check that data returned is not an error object
if not assertJsonSuccess(data):
print "Error when reading server information. " + str(data)
return
else:
print "Processed server information successfully. Now processing folders..."
# Deserialize response into Python object
dataObj = json.loads(data)
httpConn.close()
#Store the Folders in a list to loop on
folders = dataObj["folders"]
#Remove the System and Utilities folders
folders.remove("System")
# folders.remove("Utilities")
#Add an entry for the root folder
folders.append("")
folders.append("System")
#Create the summary file of services
serviceResultFile = open(resultFile,'w')
serviceResultFile.write("ServiceName,Folder,Type,Status,Min Instances,Max Instances,FeatureService,kml,wms,Max Records,Cluster,Cache Directory,Jobs Directory,Output Directory" + "\n")
#Loop on the found folders and discover the services and write the service information
for folder in folders:
# Determine if the loop is working on the root folder or not
if folder != "":
folder += "/"
# Build the URL for the current folder
folderURL = "/arcgis/admin/services/" + folder
httpConn.request("POST", folderURL, params, headers)
# Read response
httpConn.close()
return
else:
print "Error when reading folder information. " + str(data)
else:
print "Processed folder information successfully. Now processing services..."
httpConn.close()
# Loop through each service in the folder
for item in dataObj['services']:
if item["type"] == "GeometryServer":# and folder == "":
# Build the Service URL
if folder:
sUrl = "/arcgis/admin/services/%s%s.%s" %(folder,item["serviceName"], item["type"])
statusUrl = "/arcgis/admin/services/%s%s.%s/status" %(folder,item["serviceName"], item["type"])
else:
sUrl = "/arcgis/admin/services/%s.%s" %(item["serviceName"], item["type"])
statusUrl = "/arcgis/admin/services/%s.%s/status" %(item["serviceName"], item["type"])
httpConn.request("POST", sUrl, params, headers)
# Get the response
servResponse = httpConn.getresponse()
readData = servResponse.read()
jsonOBJ = json.loads(readData)
# Build the Service URL to test the running status
# Submit the request to the server
httpConn.request("POST", statusUrl, params, headers)
servStatusResponse = httpConn.getresponse()
# Obtain the data from the response
readData = servStatusResponse.read()
jsonOBJStatus = json.loads(readData)
# Build the line to write to the output file
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + "NA" +"\n"
# Write the results to the file
serviceResultFile.write(ln)
httpConn.close()
elif item["type"] == "SearchServer":# and folder == "":
if folder:
else:
# Get the response
# Get the response
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + str(jsonOBJ["properties"]["jobsDirectory"]) + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
httpConn.close()
elif item["type"] == "ImageServer":
if folder:
else:
# Get the response
if folder:
else:
# Get the response
# Extract the WMS properties from the response
wmsProps = [imageWMS for imageWMS in jsonOBJ["extensions"] if imageWMS["typeName"] == 'WMSServer']#.items()[0][1] == 'WMSServer']
if len(wmsProps) > 0:
wmsStatus = str(wmsProps[0]["enabled"])
else:
wmsStatus = "NA"
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + wmsStatus +"," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + str(jsonOBJ["properties"]["cacheDir"]) + "," + "NA," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
httpConn.close()
elif item["type"] == "GlobeServer":
if folder:
else:
# Get the response
#Build the Service URL to test the running status
if folder:
else:
# Get the response
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + str(jsonOBJ["properties"]["cacheDir"]) + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
httpConn.close()
elif item["type"] == "GPServer":
if folder:
else:
# Get the response
if folder:
else:
# Get the response
httpConn.close()
elif item["type"] == "GeocodeServer":
if folder:
else:
# Get the response
if folder:
else:
# Get the response
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
httpConn.close()
elif item["type"] == "GeoDataServer":
if folder:
else:
# Get the response
if folder:
else:
# Get the response
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
httpConn.close()
elif item["type"] == "MapServer":
if folder:
else:
# Get the response
if folder:
else:
# Get the response
# Check for Map Cache
isCached = jsonOBJ["properties"]["isCached"]
if isCached == "true":
cacheDir = str(jsonOBJ["properties"]["cacheDir"])
else:
cacheDir = jsonOBJ["properties"]["isCached"]
if len(jsonOBJ["extensions"]) == 0:
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "FeatServHolder" + "," + "Disabled" + "," + "Disabled" +"," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + cacheDir + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
else:
# Extract the KML properties from the response
kmlProps = [mapKML for mapKML in jsonOBJ["extensions"] if mapKML["typeName"] == 'KmlServer']#.items()[0][1] == 'KmlServer']
wmsProps = [mapWMS for mapWMS in jsonOBJ["extensions"] if mapWMS["typeName"] == 'WMSServer']#.items()[0][1] == 'WMSServer']
# Extract the FeatureService properties from the response
featServProps = [featServ for featServ in jsonOBJ["extensions"] if featServ["typeName"] == 'FeatureServer']#.items()[0][1] == 'FeatureServer']
if len(featServProps) > 0:
featureStatus = str(featServProps[0]["enabled"])
else:
featureStatus = "NA"
if len(kmlProps) > 0:
kmlStatus = str(kmlProps[0]["enabled"])
else:
kmlStatus = "NA"
else:
wmsStatus = "NA"
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + featureStatus + "," + kmlStatus + "," + wmsStatus +"," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + cacheDir + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
else:
# Close the connection to the current service
httpConn.close()
# Close the file
serviceResultFile.close()
def getToken(username, password, serverName, serverPort):
# Token URL is typically http://server[:port]/arcgis/admin/generateToken
tokenURL = "/arcgis/admin/generateToken"
params = urllib.urlencode({'username': username, 'password': password, 'client': 'requestip', 'f': 'json'})
httpConn.request("POST", tokenURL, params, headers)
# Read response
httpConn.close()
print "Error while fetching tokens from admin URL. Please check the URL and try again."
return
else:
httpConn.close()
return
# Extract the token from it
token = json.loads(data)
return token['token']
# A function that checks that the input JSON object
# is not an error object.
def assertJsonSuccess(data):
obj = json.loads(data)
if 'status' in obj and obj['status'] == "error":
print "Error: JSON object returns an error. " + str(obj)
return False
else:
return True
if __name__ == "__main__":
sys.exit(main(sys.argv[1:]))
Best,
Rawan
It's possible by creating a token, getting the list of services, looping through each service, grabbing the min/max instances, adding them to a counter, and getting the list of folders, getting the list of services in each folder, looping through each service, and grabbing the min/max instances, and adding them to a counter as well:
import urllib2, urllib, json, ssl
#Avoids self signed certificate errors
ssl._create_default_https_context = ssl._create_unverified_context
baseURL = 'https://<machine>.<domain>.com:6443/arcgis'
psaUsername = '<username>'
psaPassword = '<password>'
#Function to open URLS
def openURL(url,params):
encodedParams = urllib.urlencode(params)
response = urllib2.urlopen(url,encodedParams).read()
jsonResponse = json.loads(response)
return jsonResponse
serverAdminURL = "{0}/admin".format(baseURL)
tokenURL = '{0}/tokens/generateToken'.format(baseURL)
#Generates an admin token
tokenParams = dict(username=psaUsername,password=psaPassword,client='requestip',f='json')
token = openURL(tokenURL,tokenParams)['token']
rootServicesURL = "{0}/services".format(serverAdminURL)
adminParams = dict(token=token,f='json')
#Starts the min/max counters
totalMinInstances = 0
totalMaxInstances = 0
#Gets services in the root directory
rootServices = openURL(rootServicesURL,adminParams)['services']
#Loops through services
for service in rootServices:
serviceName = service['serviceName']
serviceType = service['type']
serviceURL = "{0}/{1}.{2}".format(rootServicesURL,serviceName,serviceType)
#Gets service information
serviceInfo = openURL(serviceURL,adminParams)
minInstances = serviceInfo['minInstancesPerNode']
maxInstances = serviceInfo['maxInstancesPerNode']
#Adds min/max instances to counters
totalMinInstances += minInstances
totalMaxInstances += maxInstances
print("Service {0} is configured with {1} min instances and {2} max instances.".format(serviceName,minInstances, maxInstances))
#Gets folders
rootFolders = openURL(rootServicesURL,adminParams)['folders']
for folder in rootFolders:
#Optionally go through System and Utilities folders, (you'll need to uncomment the line and fix the indentation)
#if not folder in ['System','Utilities']:
folderURL = "{0}/{1}".format(rootServicesURL,folder)
#Gets services in folders
servicesInFolders = openURL(folderURL,adminParams)['services']
#Loops through services in folders
for service in servicesInFolders:
serviceURL = "{0}/{1}/{2}.{3}".format(rootServicesURL,folder,serviceName,serviceType)
print("Service {0}/{1} is configured with {2} min instances and {3} max instances.".format(folder, serviceName,minInstances, maxInstances))
#Returns min/max instances.
print("Total minimum instances: {0}".format(totalMinInstances))
print("Total maximum instances: {0}".format(totalMaxInstances))
Dear Jonathan,
Thanks for your answer,
I tried to add the previous code in a python, but when I tried to open it it fails to work.
I couldn’t figure out what is the reason for that.
What do you think?
Best,
Rawan
Without any information about the error, it's impossible to provide assistance.
Dear Jonathan,
Many thanks for your answer.
Kindly find the following screenshots.
Best,
Rawan
The variables on line 6, 7, and 8 are simply place holders. Replace them with the appropriate information for your Server.
Dear Jonathan,
I got the same error even though I entered the specific variable
Best,
Rawan
