Yeah, the TypeScript is looking for resources that are not there, or did not install in a correct location perhaps. Although I am just getting started with esri support, it appears there are missing js files, nodemodules maybe more in at least 2 locations, instantgallery and sidebar.
When I try to config an existing app, the config template here
https://..../portal/apps/configure-template/app/ui/main/ConfigPanel/ConfigPanelViewModel.js
which is here:
C:\Program Files\ArcGIS\Portal\apps\configure-template\app\ui\main\ConfigPanel\ConfigPanelViewModel.js
can't find other ts, js, and calcite
The install appeared clean and the Event Log only reports some setupmsi application hangs, which I could see anyway when the setup wizard would become unresponsive at the beginning of my install. There are no Carbon Black events, there are some Software Protection Program (SPP) 'start' events.
But I'm totally grasping at straws. It was a bad install, don't know why
