11.2 upgrade instant apps config won't come up
4849
30
04-01-2024 12:39 PM
DavidColey
MVP Regular Contributor
Hello - I just upgraded to 11.2 from 11.1 and now my Instant apps configuration page will not display instant app choices.  What can I do?
My existing sidebar apps configured at 11.1 will not display the sidebar info panel and I cannot update them. The configuration choice from the app overview page just spins?
Any of you guys have any suggestions:
@MarceloMarques
@JonEmch
@Scott_Tansley
@JakeSkinner
@jcarlson
Thanks-
David
Scott_Tansley
Have you tried using inprivate mode for your browser.  Sounds, at first pass, like a caching issue.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
DavidColey
I run in Chrome incognito mode so often I never even checked
DavidColey
Here is the dev console from Chrome:
The Chrome console error says it can't find the Instant App Data from here:
 webpack://instant-app-landing/src/app/data/AppTypeInfo/AppTypeInfoViewModel.ts
DavidColey
the console log show lots of 'failed to load resource' . . .
DavidColey
In an earlier upgrade, I had added the following to the
D:\arcgisportal\db\pg_hba.conf file:
*Added a config setting to D:\arcgisportal\db\pg_hba.conf file:
# TYPE  DATABASE        USER            ADDRESS                 METHOD
host    all                            all            ::1/128                 scram-sha-256
I did not add this param to the pg_hba file when going from 11.1 to 11.2
Could that be it?
DavidColey
Unfortunately I can't recall why I added that param in the first place, or when.  Feels like maybe I added it going from 10.9.1 to 11.0
DavidColey
Here is something I found for a related Online version of something similar that @KellyHutchins noted
Instant App configure page will not open - Esri Community
but not quite.  It's not the Instant App page won't open, its that Portal 11.2 can't find the Instant App data per my Console log screen grab I posted above.
Anyone?
Scott_Tansley
Sorry I've been in meetings all morning and struggling to catch up on project work.  Is there any information in the network tab of developer tools, that suggests a resource is not loading or 404, 5xx errors etc.  If you use InPrivate mode all the time, then it may not offer the normal value.  What happens if you use Edge (or another) using the InPrivate mode?
Scott Tansley
DavidColey
No problem.  If you look at my earlier reply with the dev console image, you will see that the Chrome console error says it can't find the Instant App Data from here:
I have tried in Edge, both in-private and standard, and in Chrome both incognito and standard.
I've got a case in with esri, but yes there are lots of 404s, mostly with Calcite components:
..../apps/instant/node_modules/@esri/calcite-components/dist/calcite/p-f4be18ed.js
