Problems with adding CSV file as a map layer onto ArcGIS Portal
4068
7
07-04-2017 02:22 AM
CherylLim
Hi, I am trying to publish an excel sheet in CSV format onto my organisation's ArcGIS Portal but I am having issues with adding my CSV file onto the portal.
I have 727 rows and 15 columns of data in my excel sheet. Whenever I tried to add a layer from my file on the portal, I would get an Error warning even though I have included valid addresses and geographic coordinates in my excel sheet. Did anyone encounter this problem too? I have attached some images for your reference, really appreciate your help!
-Cheryl
shan_sarkar
Cheryl,
Does your csv have any special characters (!,@,#) or spaces in the field names?
~Shan
~Shan
shan_sarkar
Also can you share any one coordinate that is available for the point data?
~Shan
~Shan
CherylLim
Hi Shan,
No, my csv does not have any special characters and my field names do not contain any spaces, I have added in underscores for the field names' spaces instead.
I have added a screenshot of one coordinate for your reference, thank you for your advice!
-Cheryl
JayantaPoddar
Ensure that the Lat/Lon values correspond to the coordinate values in GCS_WGS_1984 (Decimal Degrees). Try changing the lat/lon values to its corresponding values in Decimal Degrees, and add again to the Map Viewer.
Think Location
DanPatterson_Retired
you have projected coordinates... what projection are they in? and you should recalculate them into geographic coordinates in the source program
SrinivasaRao1
Hi, we are also facing the same issue but in our CSV there are no Lat/Lan details available, is there any possibility of adding those in the ArcGIS portal without Lat/Lan details to covert into the feature layer.
As we all know that there is an option in ArcGIS online without Lat/Lan details we can add as an item in a web map and create as a feature layer.
But we required to be published in ArcGIS Portal, is there any way to publish. Below is error when we try to add from file through web map.
ReginaldoPaderon2
Any update on this ?  We are having the same issue in our Production Environment.  However, in our Development Environment, there are no issues (Development is not public).
I am having Portal 10.9.1.
