Need a Routing Service for ArcGIS Portal
1699
01-11-2019 10:33 AM
ChristopherSabo
Good afternoon. We have been using ArcGIS Portal and Enterprise for the past 3 years and really need a Routing Service. We have had issues hosting our own, as the file is so large it times out. Are there any ESRI Routing Services or publish Routing Services we can use?
Chris Sabo
ArchitSrivastava1
Esri Alum
Hello Christopher Sabo‌,
Thanks for posting this question. There are multiple ways to find a solution in the current scenario:
"Please go through the following documentation prior working with ArcGIS Online Routing service : Understand credits—ArcGIS Online Help | ArcGIS "
For more details in regards to ArcGIS Online Routing Service check the following documentation :
ArcGIS Online Directions and Routing Services
Hope it helps!
Kind Regards,
Archit
BillFox
MVP Notable Contributor
Can StreetMap Premium be used for this need?
ArchitSrivastava1
Esri Alum
Yes we can use the StreetMap Premium Data to Publish the Network Utility for ArcGIS Enterprise. The steps required to achieve the result are explained in the document below:
Publish Routing Services utility—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
This utility is introduced are ArcGIS Enterprise version 10.6.1.
Hope it helps!
Kind Regards,
Archit
