Is It Possible to Install New Map Viewer for ArcGIS Portal 10.8.1?
1833
6
09-22-2022 12:35 PM
ThomasM
I am looking to install the New Map Viewer to our Portal 10.8.1 environment. I have found where and how to install Map Viewer Beta, but cannot find any mention of the non-beta version of the New Map Viewer. Is this available? Can the Map Viewer Beta just be upgraded once it is installed?
GIS Specialist - MO Office of Geospatial Information
jcarlson
MVP Esteemed Contributor
Back then it was called the Map Viewer Beta, and had to be installed separately.
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/announcements/map-viewer-beta-in-arcgis-...
The linked article goes through all the instructions, and includes links to the installation files.
- Josh Carlson
Kendall County GIS
FraserHand
Hi Thomas,
The new map viewer is included with 10.9.1+ so when you upgrade you uninstall the Map Viewer Beta first, upgrade, then you can set the map viewer a the default viewer in the portal settings. The beta version is the only one available for 10.8.1 - the released version is in 10.9.1+.
Cheers
Fraser
ThomasM
That's what I was worried would be the case. Was hoping documentation was maybe just out of date, but I guess not. Hoping to get my org upgraded to 10.9.1 in Q1 next year.
FraserHand
For 10.8.1 your only option is to install the Map Viewer Beta as a separate install AFAIK. Just remember to remove it prior to your upgrade. I just went through the 10.8.1 -> 10.9.1 upgrade process.
Cheers
StevenBell2
You shouldn't have to install it.  Go to Organization>Settings>Map and Primary map viewer should be a choice for you.
ThomasM
That's not an option available to me. If @FraserHand is correct, then I cannot have access to the New Map Viewer without updating my entire Enterprise to 10.9.1.
jcarlson
- Josh Carlson
Kendall County GIS
