Disable password reset functionality
3186
08-04-2021 09:02 PM
AngusHooper1
ArcGIS Enterprise Portal allows you to set showForgotUsername: false in the config.js and it also allows you to disable the ability for users to create built-in accounts via the portal organisation settings page. What is missing is the ability to disable the "forgot password" interface. Using this interface allows someone to confirm/deny the existence of accounts within the identity store even if that identity is within the built-in store or a 3rd party identity store (e.g. ldap).
Is there a mechanism for disabling the ability to reset a password for an account in Portal?
STINGERSIG_EDF-DPI
this deserves an answer, when using LDAP only, forgotten password requests get sent to ESRI, that's nonsense
YatharthSah
Yes possible.
<Installation Directory>\webapps\arcgis#home
Rename the troubleshoot.html file to troubleshoot_old.html file.
It will disable Forgot password functionality
RandallWilliams
This work around is a hack and does nothing to change the back end API. It just obfuscates the troubleshoot.html page. Please log an enhancement with support to block this capability if you're using IWA OR if you're only allowing organization-specific logins.
