Cant share item to group
3340
03-11-2021 11:48 PM
JanineWhittal
I wondering if anyone else has come across this issue before. I'm trying to share an item (web map) to a group, more specifically the Featured Maps and Apps group so that the item can display on the Portal homepage, when I share it is not reflecting on the group at all. I'm using the primary admin user which also owns the item and is the owner of the group but for some reason the sharing to group doesn't work.
2 Solutions
ReeseFacendini
Esri Alum
Is the item not showing up on the Portal home page, or not within the group at all?
ReeseFacendini
Esri Alum
Can you create a new group, and share the map to it, then set that group as the one that shows content on the home page?  I'm wondering if there is something off with that default group.
ReeseFacendini
Esri Alum
JanineWhittal
Not showing in the group or home page despite ticking the group when updating the sharing.
ReeseFacendini
Esri Alum
Laura
by MVP Regular Contributor
I am having a similar issue. I have created a new group and there is 1 map & app I specifically need in it and it does not show up as an option.
