Bug in Portal for ArcGIS 10.3, Web AppBuilder ?
6217
6
04-10-2015 02:14 AM
HildegardGerlach1
We have installed Portal for ArcGIS 10.3 on Windows Server 2008.
I encounter the following problem:
I create a simple WebMap, e.g. just adding one layer (e.g. the ArcGIS server test service SampleWorldCities) to the basemap.
Then I create a Web application from this map selecting the Web AppBuilder. I leave everything to the default settings (Foldable Theme).
If I then press first the button of the Legend widget and afterwards the button of the Layer List widget (in the Header Controller), I get the following error (in a popup):
create widget error:
widgets/LayerList/Widget
Pressing the Layer List widget before the Legend widget  or using the Tab Theme, everything works fine.
Thanks
Hilde
DerekLaw
Esri Esteemed Contributor
Hi Hilde,
The issue you've described is very unusual and we are unable to reproduce it. Some things to help troubleshoot:
- Have you tried to clear your web browser cache?
- What web browser are you using? Does the same thing happen when you use the same workflow in a different web browser?
Hope this helps,
HildegardGerlach1
Hi Derek,
thanks for your reply. The problem persists in different Web Browsers (Firefox, IE, Chrome) and also after clearing the cache.
Actually a colleague of mine discovered it and I reproduced it. I also tried as a different portal user (administrator), same behaviour.
The portal is installed on an internal server, so I cannot send you the link.
Now I created a new map, just adding
Map Contents
Soil_Survey_Map: http://services.arcgisonline.com/arcgis/rest/services/Specialty/Soil_Survey_Map/MapServer
Topographic:   http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer
and from this I just create a Web application  (Share --> Make a Web Application --> Web AppBuilder)
I can see this behaviour directly on the Web AppBuilder page leaving everything to the default, pressing first the Legend button and then the Layer List (pressing the other way round everything works).
It seems that something is initialised wrongly.
I am using the Web AppBuilder for the Portal, not the developer edition.
DerekLaw
Hi Hilde,
I tried to reproduce the behavior your describing with the specific web services (from ArcGIS Online) you listed in your post and I don't see any issues. I suspect that perhaps something may be amiss with your Portal for ArcGIS installation. Please contact Esri Tech Support as they are best equipped to help you investigate and track down the issue.
Good luck,
MiltonSolano
Hilde,
I tried to reproduce the bug/issue on my own Portal for ArcGIS installation (10.3.1) but didn't find any bug/issues, just normal operation.
1. Loaded a simple webmap into the Web AppBuilder for ArcGIS
2. Leave everything to default
3. Clicked in Legend button first; all ok
4. Clicked in Layer List button; all ok
Just as Derek pointed out, you should look for ESRI Tech Support because it seems something related to your installation.
JayantaPoddar
Robert Scheitlin, GISP​ . Any help?
Think Location
RobertScheitlin__GISP
I would recommend as Derek has for you to contact tech support as this sounds like it could be a bug.
