Basemaps unavailable after upgrading to 11.2
7426
24
04-23-2024 04:55 AM
ShelbyZelonisRoberson
I recently upgraded my ArcGIS Enterprise 10.9.1 to 11.2. It is a single machine deployment. Since the upgrade, our basemaps are unavailable in both Pro and the map viewer in Portal. When clicking on the basemap options we get a screen that says "Basemaps unavailable".
I've checked all of the organization settings - the basemap gallery is set to default, and nothing was changed after the upgrade.
I have a ticket out with Esri. They said to try to re-index the Portal, even though the index counts currently show no issues. I'm going to do this later today, but I'm skeptical it will make a difference. I was wondering if anyone else is having a similar problem? Any other suggestions?
Thanks!
FYI for all - Esri tech support did provide me a fix for this finally! I would put in a ticket with them if you are having the same issue.
DavidColey
MVP Frequent Contributor
Good deal Shelby - now you can go to 11.3.  I'm finding it a lot more stable for sure, plus you get all the app upgrades.  Remember - if you can work with your IT to disable active virus scanning during the install it will go so much faster, and not throw errors.
ekanazawa
Hi @ShelbyZelonisRoberson ,
I have the same issue, how did you fix?
You’ll have to put in a ticket with Esri. They walked me through deploying a .bat file that fixed things!
GlenterpriseUK
Hi @ShelbyZelonisRoberson,
This should be the process for fixing the missing content:
BUG-000167282 for Portal for ArcGIS
Regards,
Glen
