ArcGIS Earth Blog
120
179.3K
38
| Under Consideration | I would like to be able to create a default name of my choosing for pins, lines, polygons etc. I don.t need "Untitled... by Rockhound Emerging Contributor 0 1 | 0 | 1 | |
| Under Consideration | I would like the ability to highlight a group of pins, lines, polygons, etc on the map by dragging a box or drawing a... by Rockhound Emerging Contributor 0 1 | 0 | 1 | |
| Needs Clarification | I hope you can add a feature that allows users to long-press on any KML file layer and move it up or down, with suppo... by WaleedYasir Emerging Contributor 1 1 | 1 | 1 | |
| Needs Clarification | Ability to save map projects or webmaps like in the new Google Earth app. by Y_Chau Frequent Contributor 0 2 | 0 | 2 | |
| Open | Currently the 3D extrusion and visualisation of point features does not allow for manipulation of the radius of the f... by DominicBull1 Occasional Contributor 0 1 | 0 | 1 | |
| Open | In comparison to a Web Scene there are noticeable differences with how 3D extrusion of layers is handled in ArcGIS Ea... by DominicBull1 Occasional Contributor 1 1 | 1 | 1 | |
| Open | Labeling in ArcGIS Earth is not supported for the KML format. (https://doc.arcgis.com/fr/arcgis-earth/use/apply-label... by VirginieLe_Gal Occasional Contributor 0 1 | 0 | 1 | |
| Open | Currently, any volume (extruded polygon with elevation) is anchored/extruded to the ground. There are use cases wher... by Jay_Gregory Frequent Contributor 1 6 | 1 | 6 | |
| Open | While it is great that users will be able to create pdfs of data in ArcGIS Earth, this is going to become a mess in t... by NicoleAClothier Emerging Contributor 3 1 | 3 | 1 | |
| Open | Hi there,Vertical exaggeration of the ground is great for emphasizing terrain. However it falls over if you have 3d f... by Marc_Graham Frequent Contributor 1 0 | 1 | 0 | |
| Open | An awesome new feature is the ability to add a label on KML/KMZ lines and polygons. But the labels are deactivated ev... by GeoffroyRicher-Lalonde Frequent Contributor 0 1 | 0 | 1 | |
| Open | In ArcGIS Earth, it would be helpful to be able to search by account number from an attribute table field and be able... by JulietteWood Occasional Contributor 0 0 | 0 | 0 | |
| Open | It is impossible to select multiple Placemarks and move them into an existing folder. You must use the Group function... by GeoffroyRicher-Lalonde Frequent Contributor 0 2 | 0 | 2 | |
| Open | We have just deployed ArcGIS Earth 2.3 in a disconnected environment and have noticed the new Survey123 submission wi... by EdenPunter Occasional Contributor 1 3 | 1 | 3 | |
| Open | When editing a ArcGIS Online feature layer (hosted and View), filter the open attribute table to show only selected r... by DavidLittlejohn Occasional Contributor 0 1 | 0 | 1 |
Idea Submission Guidelines
