ArcGIS Earth Ideas
ArcGIS Earth Ideas
Other Boards in This Place
Latest Activity (64 Idea Submissions)
Sort/Filter :
Open
Users can export their selections from the Attribute table with the Export selected button* :* if the <enableTableDat...
GeoffroyRicher-Lalonde
by GeoffroyRicher-Lalonde Occasional Contributor
in ArcGIS Earth Ideas Last Updated a week ago
0 1
Open
The Attribute table can be filtered by the extent, and it is a great tool.It would also be great to have an option to...
0 3
Open
When a user adds a service that contains related tables, he won't be able to see the related records using the Attrib...
in ArcGIS Earth Ideas Last Updated 2 weeks ago
1 1
Open
The ability to customize the legend on export. If I have several layers in my map, I can't add a legend without it ta...
NWhittaker
by NWhittaker New Contributor II
in ArcGIS Earth Ideas Last Updated 10-20-2023
1 1
Open
It is presently impossible to draw a polygon with holes in ArcGIS Earth. It would be an improvement to be able to do ...
in ArcGIS Earth Ideas Last Updated 10-07-2023
0 1
Under Consideration
Good day:Here is my idea: Please add snapping functionality to ArcGIS Earth. This should be a basic requirement when ...
BryanAustin
by BryanAustin New Contributor II
in ArcGIS Earth Ideas Last Updated 07-28-2023
2 1
Under Consideration
It would be helpful to be able to import GeoPDFs without having to convert them to another format.Often we receive Ge...
SarahWillett
by SarahWillett New Contributor III
in ArcGIS Earth Ideas Last Updated 07-17-2023
0 1
Under Consideration
In ArcGIS Pro, the project name and the map name are shown in the header :It could be useful to do the same in ArcGIS...
0 1
Closed
Portal connections should be managed in the main ArcGIS Pro application for all other Esri applications.  It does not...
EricEagle
by EricEagle Occasional Contributor III
in ArcGIS Earth Ideas Last Updated 06-30-2023
0 2
Under Consideration
This is regarding an issue we have with the ArcGIS Earth app for Android. We are trying to use a local SLPK mesh file...
ChristianBPedersen
by ChristianBPedersen Occasional Contributor II
0 3
Open
ArcGIS Online users can consult their Web Maps in different ways : ArcGIS Pro, web browser, ArcGIS Earth, etc. Howeve...
in ArcGIS Earth Ideas Last Updated 06-26-2023
1 1
Under Consideration
It would be great if there was a legend in ArcGIS Earth mobile. On my Android device, and confirmed with tech support...
RichOchs
by RichOchs New Contributor III
in ArcGIS Earth Ideas Last Updated 05-24-2023
1 1
Under Consideration
The same as ArcGIS Pro on a windows machine can connect to a GPS and show location and log tracks, add the same suppo...
yigalm
by yigalm New Contributor III
in ArcGIS Earth Ideas Last Updated 08-08-2023
3 2
Under Consideration
The user can choose to use different Location Units :But the user cannot choose to use the negative symbol for South ...
in ArcGIS Earth Ideas Last Updated 05-12-2023
0 1
In Product Plan
It would be nice to identify what TOC layer a map feature is sourced from. Ideally, a user could select a feature or ...
BrettLessner
by BrettLessner Occasional Contributor
in ArcGIS Earth Ideas Last Updated 04-04-2023
0 1
80 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Top Kudoed Ideas (last 30 days)
Top Kudoed Authors
