Serial Chart: Any way to hide "Show all"
1113
06-06-2019 04:44 PM
jessneuner1
New Contributor II
Heya!
We are working on a weather dashboard that includes the current value along with a chart showing the values from the past 24 hrs (at most 96 values for a particular weather tower).   The source table for the charts contains all values for all towers (5 towers total) for 48 hours -- but is then filtered at run time to show only the last 24 hours for one tower.
When the charts draw, they all show this "Show all" button. and when you click it, maybe more data comes in (though the overall trend of the chart doesn't change), but the lines for the values change -- and it's confusing for our users.
Is there a way to turn the "Show all" thing off or prevent it from displaying? Perhaps there's something in the way it's configured causing it to show up?
We are using Portal 10.6.1 for this one...
Charts when the dashboard first loads....
and after clicking "Show all"
DerekLaw
Esri Esteemed Contributor
Hi Jess,
The behavior you're describing looks like this might be a bug. Can you please contact Tech Support and open an issue so we can get detailed repro steps? Sorry.
Hope this helps,
jessneuner1
New Contributor II
Thanks, Derek!
no worries!  After posting this, I was working on some different charts and had the same thought - that perhaps there was a bug. I'll submit something to tech support.
thank you!
MattSund
New Contributor III
Hi Derek - sorry to post on an old one but its the only mention I can find. I also have this question. Any resolution?
