How to display the "count" of each field?
1264
03-30-2023 10:56 AM
AmyKou
How do I display the count next to each field in the category selector of a dashboard?
jcarlson
MVP Esteemed Contributor
As far as I know, there's no way to do this in a category selector, at least, not without using some fancy Arcade expressions. But if it's acceptable, you can use a grouped list, chart, or table to act as your category selector.
- Josh Carlson
Kendall County GIS
Omar_A
by Esri Contributor
Hi Amy,
Try to enable the "Display Count" option in the category selector settings!
Best,
Omar
jcarlson
Where is that setting? I've not seen it.
- Josh Carlson
Kendall County GIS
AmyKou
Ok, I probably have an older version of Enterprise and the dashboard doesn't have this option yet. I'm on Enterprise 10.9 or something
