Creating a multi-feature Pie Chart/Serial Chart
920
05-18-2021 01:30 PM
Henry
Hi all,
I'm working on a running dashboard that summarizes daily field work performed by our organization's field crew. Fieldwork is collected with Point and Polygon features.
Both features have a field in their data schema that records area units in Sq. Ft and Acres.
I'm wondering if its possible to create a single Pie or Serial Chart that will use both the Point and Polygon feature as its data input, reference the same field for categorization - and present a sum per category.
I'm able to do the sum for each point/polygon independently but it would be great if I could have something that visualizes the total are/category for both features.
Might be a bit of a stretch . . .
Henry
