Web Cameras, Web Scenes
7326
16
06-28-2013 10:34 AM
LukeCzar
Hi!
I would like to add a web camera into Web Scene, so If I will click on the object I will have an option to see how the place looks in real life (I saw it in one of your online tutorials)
xinlongliu
You can read more about IFRAME attributes in CE here: http://urban-scene.blogspot.com/2013/09/where-to-start.html
Hi,i couldn't not open the html.Is there any wrong?
xinlongliu
This is exactly where I found my answer 🙂
lukasz
Hi,could you tell me how to set the iframe?I added a picture on the model.I want to see the picture when i click the model.I set the picture under the folder.But it didn't work correctly.[ATTACH=CONFIG]32097[/ATTACH].The src i set is below
<ifram src="e:\CityEngine\gym\globe.jpg"></iframe>.Is there any wrong?
LukeCzar
Hi!
I am not 100% sure, but I think you need to place your photo on server, you can use google drive and copy the image location
for instance it will look like that : "http://www.googledrive/my_photo.jpg" and then you need to add the whole code to attribute :
<iframe height="405" width= "600" src="http://www.googledrive/my_photo.jpg" ></iframe>
You should check Carl's Blog :
http://urban-scene.blogspot.com/2013...-to-start.html
Lukasz
xinlongliu
Hi!
<iframe height="405" width= "600" src=  "http://www.googledrive/my_photo.jpg" ></iframe>
Lukasz
Hi,thanks for your reply.I achieved it.However,i have another problem.The below is my picture[ATTACH=CONFIG]32134[/ATTACH].The pane is very small.The other is the example's picutre[ATTACH=CONFIG]32135[/ATTACH].How to achieve this effect.
xinlongliu
Hi!
Lukasz
I couldn't visit the blog.Is there any wrong?or Could you screen shot it?Thanks
LukeCzar
You should play with this numbers : <iframe height="405" width= "600" src="http://www.googledrive/my_photo.jpg" ></iframe>
I am not sure, but it is not possible to extend that Green Bar(without chanting the code)
In the Blog there is a tutorial how to add attributes and paste video/photo - which you already did
Lukasz
LukeCzar
You can read more about this here :
http://forums.arcgis.com/threads/95340-embedded-link-webscene
Lukasz
