Export from City Engine with Attributes
3239
02-28-2014 12:38 AM
ManmohanKarn
I am struggling to export City Engine Model with attributes to any format. I need to export to Collada or KMZ format & keep the attributes such as object ID. the reason is that I want to keep a relationship between 2D & 3D map.
Please suggest how this can be done.  I would appreciate few quick responses.
ManmohanKarn
Thanks for reply,I have some more query regarding export collada and kml format,It will really great if you help some more,
Question is may I find object id after export model in collada and kml format,means how can I find such building have such id.
MatthiasBuehler1
Hi !
attribution in dae/kml/kmz is not yet implemented. it's on the wishlist.
use the esri formats for this ( preferred GDB ).
ok ?
m.
ManmohanKarn
