3WS Output doesnt load on browser , stays on Initializing
7164
12
03-04-2013 10:36 PM
vipulsoni
I have been working on cityengine for quite a while and now I am facing a peculiar problem for one of my generated output of 3ws.
The project in cityengine is opening perfectly without any issues and I am able to export successfully like my earlier projects to 3ws files,but for the current project the generated output 3ws in not able to load on webviewer. The viewer hangs on the initializing part.. and stays there.. I have put here the text from the webviewer, everything seems normal until the project doesn't load.
Mathias , please suggest for any pointers to fix the problem, why this project has issues.
16ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
16ms: Loading scene file : /models/new model.3ws
60ms: Server does not return gzip encoding header
60ms: Fallback to custom unzip on arraybuffer and custom streamParser
4487ms: Downloading ADAC-GIS 3D Webscene: 100% (14.81 of 14.81 MB)
4529ms: Requested gzipped data, got gzipped data
4530ms: Using custom unzip and streamparser on arraybuffer
25188ms: Reading: 98% (57.25 of 58.51 MB)
25328ms: Data loaded in 26 seconds
25328ms: Initializing...
Sheen_EiseleLenon1
I'm having the same problem with the Web Scene that I have just created. And upon checking, all the web scenes that I have created before no longer loads properly in the web viewer.
How do I resolve this issue? My browser is updated, as well as my graphics drivers. Thanks!
Marian Marigmen
11ms: CE Web Viewer version: 3.10 [ 3.10.0.201511160532 | html:3.10.0.201511160532_ ]
28ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
SHADING_LANGUAGE_VERSION: WebGL GLSL ES 1.0 (OpenGL ES GLSL ES 1.0 Chromium)
VENDOR: WebKit
RENDERER: WebKit WebGL
EXTENSIONS: ANGLE_instanced_arrays, EXT_blend_minmax, EXT_frag_depth, EXT_shader_texture_lod, EXT_sRGB, EXT_texture_filter_anisotropic, WEBKIT_EXT_texture_filter_anisotropic, OES_element_index_uint, OES_standard_derivatives, OES_texture_float, OES_texture_float_linear, OES_texture_half_float, OES_texture_half_float_linear, OES_vertex_array_object, WEBGL_compressed_texture_s3tc, WEBKIT_WEBGL_compressed_texture_s3tc, WEBGL_debug_renderer_info, WEBGL_debug_shaders, WEBGL_depth_texture, WEBKIT_WEBGL_depth_texture, WEBGL_draw_buffers, WEBGL_lose_context, WEBKIT_WEBGL_lose_context
MAX_TEXTURE_SIZE: 16384
MAX_RENDERBUFFER_SIZE: 16384
MAX_VERTEX_TEXTURE_IMAGE_UNITS: 16
562ms: Loading webscene id : eae2aa5ca6224631947cc9c5550b0262
569ms: Fallback to custom unzip on arraybuffer and custom streamParser
6613ms: Unable to load data : http://www.arcgis.com/sharing/rest/content/items/eae2aa5ca6224631947cc9c5550b0262/data
6613ms: Unable to load URL Error status 0 on http://www.arcgis.com/sharing/rest/content/items/eae2aa5ca6224631947cc9c5550b0262/data
6618ms: Downloading: 0% (0 of 11.16 MB)
khairulamri
I tried to download your data, and view through offline viewer,
here is the log :
29150ms: Loading scene file : Bonifacio_Final.3ws
29752ms: Using custom unzip and streamparser on arraybuffer
31197ms: Reading: 76% (16.63 of 22 MB)
31266ms: Invalid Web Scene (3ws) data clarinet parser error in Bonifacio_Final.3ws: Error: Max buffer length exceeded: textNode Line: 1 Column: 883400 Char:
seems your data is not valid or corrupted.
Sheen_EiseleLenon1
Hi, khairul amri​.
I can't also load the web scenes which I was able to do so before.
Details
Downloading: 0% (0 of 18.84 MB)
29ms: GL detect: WebGL 1.0 (OpenGL ES 2.0 Chromium) More
VENDOR: WebKit
425ms: Loading webscene id : d3177637843e4fd39517540834befd76
433ms: Fallback to custom unzip on arraybuffer and custom streamParser
6394ms: Unable to load data : http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/d3177637843e4fd39517540834befd76/da...
6395ms: Unable to load URL Error status 0 on http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/d3177637843e4fd39517540834befd76/da...
6401ms: Downloading: 0% (0 of 18.84 MB)
Here's another one:
Downloading: 0% (0 of 8.54 MB)
12ms: CE Web Viewer version: 3.10 [ 3.10.0.201511160532 | html:3.10.0.201511160532_ ]
VENDOR: WebKit
597ms: Loading webscene id : 97c5ee191b8e43ceb1b700309962e608
608ms: Fallback to custom unzip on arraybuffer and custom streamParser
6163ms: Unable to load data : http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/97c5ee191b8e43ceb1b700309962e608/da...
6163ms: Unable to load URL Error status 0 on http://geodatasystems.maps.arcgis.com/sharing/rest/content/items/97c5ee191b8e43ceb1b700309962e608/da...
6169ms: Downloading: 0% (0 of 8.54 MB)
CityEngine Web Viewer Help
I was able to properly open these web scenes just a few weeks back. What could be the reason(s) that they are not loading now? Thanks!
Marian Marigmen
