ArcGIS Business Analyst Pro: ArcMap Equivalency (September 2020)
1272
09-17-2020 03:59 PM
HelenBrown
Please see the latest ArcGIS Business Analyst Pro features released and upcoming features for ArcMap equivalency.
Geo-Processing Tools
Released
Near to mid- term
Long-term
Analysis
-        Enrich layer (formerly Spatial Overlay)
-        Desire Lines
-        Assign Customers by Distance (formerly Assign by Closest Store Location)
-        Customer Profiling
-        Customer Prospecting by Demographic Data
-        Customer Prospecting by PCA
-        Find Similar
-        Mean Store Center
Customer Setup Most of the functionality in this toolset is covered by Geocoding and Core Mapping functionality
Assign Customers by ID
-       Create a Customer Layer with Address Data (in ArcGIS Pro)
-       Create an Empty Customer Layer (in ArcGIS Pro)
-     Setup Customers using Existing Data, Tabular Data, XY Data (in ArcGIS Pro)
-       Assign by Trade Area
Modeling
-       Huff Model calibration (formerly called Advanced Huff Model)
-       Huff model Calibration by Real Data
-       Original Huff Model
Reports
-       Summary Reports includes Batch Reports, Export Reports (formerly Quick Reports)
-       Map series (in Core Pro. Formerly Core Mapping and arcpy.mp include Map Layout Report, Map Series Report)
-       Locator Report
Average Drive Time Report
Benchmark Report
Business Points Reports
Customer Demographic Comparison Report
Customer Geographic Summary Report
Distance Decay Report
Market Ranking Report
Summarize Points Report
Wind Rose Report
Segmentation Analysis
Target Marketing includes:
-       Target Penetration Map (formerly Segmentation Penetration Map)
-       Target Map
-       Market potential and report
-       Target group map in Target Marketing (Formerly Game Plan Map)
-       Market area gap analysis and report
Target Marketing reports:
-       Core and Dev Segments Segmentation Report
-       Customer Demographic Profile Report
-       Market Potential Volume Report
-       Match Level Summary Report
-       MRI Segmentation Report
-       MRI Understanding Market Report
-       Profile Segmentation Report
-       Profile Volume Segmentation Report
Segmentation Profiles
-        Market Area profile (formerly Create Profile by Area Summation)
-        Create Profile by Customer Layer
-        Import Segmentation Profile (formerly Create Profile by Import from Table)
-        Create Target Group
-        Survey Profile
Store Setup Most of the functionality in this toolset is covered by Geocoding and Core Mapping functionality
-        in ArcGIS Pro
o   Create a Store Layer with Address Data
o   Create an Empty Store Layer
o   Setup Store using Existing Data, Tabuler Data, XY Data
Thematic Mapping Most of the functionality in this toolset is covered by Core Mapping capabilities
Symbology
Trade Areas
-        Create Trade Area from Geography Levels, Online Geography Levels, Sub-geography layer, generate trade area from overlay
-        Customer Derived Areas
-        Threshold Rings (rings, drive times)
-        Static Rings
-        Market Penetration
-        Measure Cannibalization
-        Drive Time Trade Area
-        Generate Customer Derived Trade Areas
-        Remove trade Area Overlap
-       Data Driven Rings
-       Threshold Data Driven Ring
-       Dissolve by Attribute Range
-       Huff's Equal Probability Trade Areas
-       Monitor Trade Area Change
Territory Design
Import Territories from Database
Create Territory Solution includes the following:
-       Create Territories
-       Setup Territory Extent by Current Selection
-       Territory Design Build Network Index
Import Territory Solution
Export Boundaries and Variables (includes Export Data and Territories
Solve Territories includes the following:
-       Balance Territories
Add Level Variables (formerly Add Territory Level)
Set Balance Variables (formerly Setup Level Balancing Variables)
Set Territory Attribute Constraints (formerly Setup Level Capacity Constraints)
Set Territory Distance Parameters (formerly Setup Level Distance Constraints)
Add Territory Barriers (formerly Setup Level Territory Shape Parameters, Setup Solution Barriers, Setup Solution Restricted Areas)
Generate Territory Report (formerly Create Territory Report)
-        Compare Territory Solutions
-        Create Detailed Territory Report
-        External index for territory design
-       Import Variables by Attribute Join
-       Import Variables by Spatial Join
Non-Geoprocessing functions
Released
Near to mid-term
Long-term
Business Listings
Evaluate Site
Color Coded Maps
Custom Data
Color Coded maps ribbon
Dynamic Ring Analysis
Smart Map Search
Address Coder
Report Authoring
Preferences
Analysis Extent
Territory Design
-       Resolve Overlapped Territories
-       Information Views (Statistics, Data, Hierarchy, Charts)
-       Unassigned Territories
-       Drag and Drop Territories
-       Reassign View with "What-If" data
