Clang error during Cloud Make process for iOS
We use the Cloud Make process to create the installation files for our mobile app. We're trying to create a final build before AppStudio is withdrawn next month but when trying today we received an error with the iOS build (the Android app was built successfully): The error says: clang: error: unable to execute command:…
Hello Cloud make not working today , still in Queue !!!
Hello appstudio , Kindly note that the Cloude make not working today , the requests still in Queue Please @AdityaAllamraju1 , @TrevorFrame you can help me
August 2024 Update for AppStudio 5.5
To maintain compatibility with current Google Play Store requirements we have released an incremental update to the cloud make service for ArcGIS AppStudio 5.5. * The AppStudio cloud make service has been updated to target Android 14 (API level 34). This update meets new "Target API level requirements for Google Play apps"…
IP Address Not Found | ESRI Army Museum Brick Locator App
I've been trying to reach our contact as our brick locator app - https://d2w57y8pj5qw5b.cloudfront.net/ is currently resolving as an IP address that can not be found. From a customer service standpoint I'm extremely dismayed and hope that posting in mulitple communities may be helpful in troubleshooting this situation.…
April 2024 Update for AppStudio 5.5
To maintain compatibility with current Apple App Store requirements we have released an incremental update to the Cloud Make service for ArcGIS AppStuidio 5.5. * Cloud Make now supports XCode 15 for iOS and macOS builds, to meet the April 2024 App Store requirements. https://developer.apple.com/news/?id=fxu2qp7b * The App…
Is the Cloud Make process broken at the moment?
We use the Cloud Make process to create the installation files for our mobile app. Normally after pressing the Request Build button the build process starts after just as few seconds. However, this morning I requested a build and it's just sitting there saying 'Queued' (it's been >30 mins now, which is very unusual): It…
AppStudio Cloud make fails
When I call cloud make from App studio, it goes to the screen where it shows a small error in the bottom left. When I click on this it gives an error message - Build request failed. Error 403 - You do not have permission to this resource or operation. From what I understand, cloud make should be available till Feb 2025.…
Will iOS SDK version used by AppStudio be updated before 29th April 2024?
This is a question for ESRI staff really, maybe @ChrisLeSueur. At the moment when we create a new version of our app in AppStudio, when we do the build we get the following warning regarding the iOS SDK version used to build the app: "ITMS-90725: SDK version issue - This app was built with the iOS 16.1 SDK. Starting April…
Debug build failing for Android
I have implemented the jacoco coverage report for my android app. Since i have implemented it and try to build the debug app and run the jacoco commands to generate reports i am getting below issue . Please suggest the solution for it. * What went wrong: Execution failed for task ':app:mergeExtDexStagingDebug'. > Could not…
Is Networking module has SSL pinning as security
Greetings, i would to help us how i can setup ssl pinning using appstudio for arcgis networking QML that check the public key of the server , that required from security team that deprived middle ware attack So my question is the appstudio framework provided the ssl pinnig via Networking module or NetworkRequest QML Please…
AppStudio 5.5.180_Unable to create quick report
Hi all, I am seeking for help. I am following an instruction to create Quick report via Appstudio: https://learn.arcgis.com/en/projects/use-arcgis-appstudio-to-build-a-311-mobile-app/ I am using IOS, Sonoma 14.1.One of other student is using Windows. The App Studio is 5.5.180, downloaded from…
How do i get the Tile Package Kreator
Hey, im trying to get the Tile Package Kreator but cant find it. can someone help. Thanks.
Odd iOS Make Error,
I'm trying to run a Make for iOS, and I'm running into the very odd error message below after it begins. Has anyone seen this one before? AppStudio 5.5.180. I've built this app multiple times in the past, and haven't encountered this particular issue before. No…
Request gallery permission for Android 13
I have an app developed in appstudio with qml and I need to maintain the gallery access permission. I was reading that for Android 13 the way to request the gallery has changed. In the Android Developers community it's indicated to call it MediaStore.Images, but I'm having trouble implementing it in qml.…
AAB generation with Cloudmake
How to generate AAB files using Appstudio Cloud Make? When I request Android builds I only get APK files, but since I am in the process of publishing an application in the Google Play Store and it only accepts bundles.
ImageObject Save Fails
I am converting an image from the HEIC format to jpg in order to upload as an attachment. The ImageObject save method does this but it only returns true or false. I'm getting lots of false returns resulting in a selected image not being available to upload for my users. Is there any way to get more information about why…
August 2023 Update for AppStudio 5.5
To maintain compatibility with current Google Play Store requirements we have released an incremental update to the Cloud Make service for ArcGIS AppStuidio 5.5. With this update any Android builds generated with Cloud Make will be set to target Android 13 (API level 33) and will be compliant with Google Player store…
App publishing to Google Play needs higher Android API level
Hi, When we are trying to publish our app to Google Play, we get notification warning that it must meet Google Play’s target API level requirements. By Google Play console our app API level is version 12 of Android We make Android package using AppStudio Cloud make. Is it possible to upgrade to version 13 of Android…
Android Local Build Failing
I have other posts about the tools needed to build. But I don't know if the wrong install tools on windows are what is causing the local build to fail. I have installed qt 5.15.6 and some of the required tools (I think they are right), but when I run the build it continues to fail at this point near the end of the build.…
Windows Android Local Build
I could really use some help on the local build requirements for Android build. I cant seem to get the Android Studio SDK manager to work with the proper configuration? I have tried multiple versions of Android/NDK/Tools. Then in qt creator (options-->devices) the Android settings are all wrong. The build never seems to…
Local Build Android Install Dev Tools
https://doc.arcgis.com/en/appstudio/extend-apps/installdevtoolslocalmake.htm Does anyone know if the local dev tool requirements for Android (Build on Windows) is out of date? My local build doesn't seem to produce the apk file. It completes successfully, but only a .so file is a result. Here is my local build setup on…
Configure Secure Service in App Studio
I have created an application in ArcGIS App Studio that consumes a REST service. This application is public and will be in the stores. This REST service was added as an item in the Portal for ArcGIS and portaladmin credentials were configured. The REST service was shared with a user group, and the user credentials are in…
AppStudio : iOS session doesn't persiste
Hello @ALL I already posted this question on Qt Maps SDK Questions community and get redirected to AppStudio Community My mobile app session under IOS doesn't persist after closing : the user needs to login every time to use the application For my Android version, the user needs to login the first time only, then the…
Push Notifications QML
What happened to Push Notifications? last plan was to be released mid 2021 but nothing came out of, and to this point no follow up to subject. We used a WebSocket to circumvent the issue. However, since google decided to prevent apps from working in the background back in 2021 this is no longer viable at all. We are hard…
Apps Developed and Published using App Studio Developer License
Hi Esri Developers, I want to upgrade my license to ArcGis App Studio developer subscription, but I have a basic question that "Do Apps developed and published using App Studio disable if the subscription period is over?"
