Use a csv file to append data to a feature layer on AGOL
2154
09-01-2022 12:13 AM
Admin_D
I would like to use a CSV file to append data to an existing feature layer on AGOL .  I found several sources such as below but I could not figure out how to implement them in my case.
https://developers.arcgis.com/python/guide/appending-features/#append-attribute-values-from-a-csv
csv_name = update.csv
Item_id (on AGOL ) = 'f5f917dab40e46d4a83c4a11f8b7b681'
csv_path  = 'C:\Test'
Do you have any idea how can I update this feature layer using the append() function?
Tags (3)
Jacob_Helfman
First, you need to connect to your AGOL site, then add()  the CSV as an item to AGOL.
Then, you can create a Feature layer object using the layer's url, then append()  to the feature layer. See https://developers.arcgis.com/python/api-reference/arcgis.features.toc.html#featurelayer
Note: Make sure the field mappings are correct to ensure the append works. If you have example names for the AGOL site and items, I can send a test script for you.
