Upload a csv file with poly data and generate points (centroids)
2595
08-18-2023 10:21 AM
Labels (3)
DonaldPike
I have a python script that performs the following:
1) Exports csv data from a feature layer (that contains polygons and centroids that were generated from the polygons)
2) Performs some external processing on the data (this performs some logic joining original and related data that the internal feature for joining tables in arcgis can't handle, hence the need to do it externally)
3) Imports the processed csv data back into arcgis, creates a feature layer from the data, and associates the feature layer with a webmap
I'm running into an issue with step #3, where I need to recreate the centroids from the uploaded csv data, and I'm hoping I can do this in an automated fashion within the same python script.
Here's the pertinent section of the code (stripped down for readability):
def generate_points_2(params):
    gis = GIS("https://fotnf.maps.arcgis.com/", "XXXX", "YYYYY")
    print(f"Connected to {gis.properties.portalHostname} as {gis.users.me.username}")
    arcpy.AddMessage(f"Connected to {gis.properties.portalHostname} as {gis.users.me.username}")
    snake_case_random = uuid.uuid1()
    csv_file_orig = args.data_path / f"Joined.csv"
    csv_file_new = args.data_path / f"Joined_{snake_case_random}.csv"
    shutil.copy(csv_file_orig.resolve(), csv_file_new.resolve())
    csv_agol = gis.content.add(item_properties={
        'title': f"Test CSV polys {snake_case_random}",
    }, data=csv_file_new.as_posix())
    csv_agol.move(f'Oliver')
    feature_layer = csv_agol.publish()
    sr = 4326  # or whatever your spatial reference is
    feature_layer = FeatureLayer(feature_layer['url'] + '/0')
    # query features to dataframe
    df = feature_layer.query(
        as_df=True,
        return_centroid=True,
        return_geometry=False,
        out_sr=sr
    arcpy.AddMessage("Here 61")
    # convert centroid to dict
    # ordinarily I don't like long single lines, but there's no point in assigning all the intermediate outputs to their own variables
    sdf = GeoAccessor.from_xy(df.join(pd.DataFrame(df.loc[:, 'centroid'].to_dict()).T), 'x', 'y', sr=sr)
But this line:
        as_df=True,
        out_sr=sr
Generates the following error:
'returnCentroid' parameter is invalid
Return geometry centroid is only supported on layer with polygon geometry type.
(Error Code: 400)
I found the following suggesting for what appears to be a similar issue:
https://community.esri.com/t5/data-management-questions/import-csv-data-and-convert-to-polygon-shape...
But that thread is quite old (2015) so I'm wondering if that would still be the right direction to take or if there would be another, possibly simpler, approach?
David_McRitchie
Hey Donald,
Reading this I think the thread you linked will be the course to take. From your code you are loading the csv file holding your polygons into the query and so this expects a Feature Layer to which it can query the geometry.
As a result you will need to have your CSV converted into a Feature Class first before querying it.
Hope that helps,
David
Esri UK -Technical Support Analyst
David_McRitchie
Hey Donald,
Hope that helps,
David
Clubdebambos
MVP Regular Contributor
Hi @DonaldPike
Check out this link
When running....
.... use publish parameters as per below for example (see link above for params, scroll down to CSV publish parameters JSON properties)...
publish_parameters = {
    "type" : "csv",
    "name" : "TABLE NAME",
    "locationType" : "coordinates",
    "latitudeFieldName" : "LAT",
    "longitudeFieldName" : "LONG"
feature_layer = csv_agol.publish(publish_parameters=publish_parameters)
 This will create a point feature layer in a feature service.
~ learn.finaldraftmapping.com
DonaldPike
Here's the code that we ended up using to generate the centroids:
(inspired by this post: https://community.esri.com/t5/data-management-questions/import-csv-data-and-convert-to-polygon-shape... )
def generate_points(_args):
    gis = _args.gis
    poly_feature_layer = gis.content.get("7da90f1a777c4d6e9d59e3314e70fbe5")
    arcpy.AddMessage(poly_feature_layer["url"])
    poly_feature_layer2 = FeatureLayer(poly_feature_layer["url"] + "/0")
    # EPSG 4326 is a coordinate system for lat/long that makes used of the WGS84
    # spheroid
    sr = 4326
    df = poly_feature_layer2.query(
        as_df=True, return_centroid=True, return_geometry=False, out_sr=sr
    arcpy.AddMessage(df.iloc[0])
    # Convert centroid to dict
        df.join(pd.DataFrame(df.loc[:, "centroid"].to_dict()).T),
        "x",
        "y",
        sr=sr,
    arcpy.AddMessage("Here 62")
    arcpy.AddMessage(sdf.iloc[0])
    sdf = sdf.drop("Correct_Area_SqM", axis=1)
    arcpy.AddMessage("Here 63")
    # Create a shortened uuid to avoid name clashes.
    # We made want to add cleanup for all temporary layers.
    tmp_uuid = "".join(
        random.choice(string.ascii_letters + string.digits) for _ in range(6)
    arcpy.AddMessage(tmp_uuid)
    new_feature_layer = sdf.spatial.to_featurelayer(
        title=f"Polys Centroids {tmp_uuid}",
        gis=gis,
        tags=["centroids", "outputs"],
        folder="Oliver",
        sanitize_columns=False,
        service_name=f"polys_centroids_{tmp_uuid}",
    return new_feature_layer
