Strange results from Workforce Module
809
01-22-2025 01:20 PM
CodyPatterson
MVP Regular Contributor
Hey all,
Enterprise 11.2
Having a strange thing happening with Workforce, when creating the Workforce assignment and appending it to a list, the assignments all turn into <Assignment None>.
When attempting to batch_add said list of assignments, I get an error stating that 'NoneType' object has no 'properties', here is my setup:
            NewLocates.append(
                workforce.Assignment(
                    project,
                    geometry=pt,
                    location=Location,
                    description=x,
                    priority=int(Priority),
                    work_order_id=Record["CaseNumber"],
                    assignment_type=TicketType,
                    status="unassigned",
                    due_date=TicketInfo['DueDate']
    print(NewLocates)
    project.assignments.batch_add(NewLocates)
Any idea what could be happening here? I've attempted to batch add a single item in a list, and attempted to use just add, neither worked. I've also checked that every item inside of the Assignment function is valid, well valid to my mind.
What should I do next?
Thanks in advance!
CodyPatterson
Hey All,
Update, looks like there was a bug: https://support.esri.com/en-us/bug/the-following-error-message-typeerror-object-of-type-fe-bug-00017...
This bug was about ArcGIS version 2.3, and when moving up to 2.4, it worked without most issues. I'm still having one or two, but nothing crazy.
Cody
CodyPatterson
Hey All,
Cody
