Smartsheet to AGOL
1274
02-12-2024 10:05 AM
Labels (3)
drWood
I am trying to follow the steps provided in this blog: https://community.esri.com/t5/arcgis-api-for-python-blog/updating-arcgis-online-hosted-feature-layer... and cannot find a solution to encountered errors when running from the Python window in ArcGIS Pro 3.2.1
import smartsheet
import pandas as pd
from arcgis.gis import GIS
access_token = 'xxxxx'
smartsheet = smartsheet.Smartsheet(access_token)
sheetID = '1234567890'
def smartsheet_to_dataframe(sheet):
col_names = [col.title for col in sheet.columns]
row = []
for row in sheet.rows:
cells = []
for cell in row.cells:
cells.append(cell.value)
rows.append(cells)
data_frame = pd.DataFrame(rows, columns=col_names)
return data_frame
sheet = smartsheet.Sheets.get_sheet(sheetID)
df = smartsheet_to_dataframe(sheet)
output_csv = r"C:\TEMP\temp.csv"
df.to_csv(output_csv)
My attempts to run this script keep prompting the error:
File "<string>", line 22, in <module>
File "<string>", line 11, in smartsheet_to_dataframe
AttributeError: 'Error' object has no attribute 'columns'
Some digging made mention that the arcpy version the environment is directed to may not be compatible with the functions being used, but I have not been able to make any headway regarding that.
Thanks in advance for any help!
Raul
Haven't really ever used the smartsheet library myself, but frrom the sample code you posted (you should fix the indentation btw) I'd try renaming the variable on line 6 to something else, so it doesn't have the same name as the library you're trying to use.
CraigCheeseman
Did you clone your default environment and make sure that is where you installed your version of the sdk?
