Sharing after using clone_items()
3975
12-30-2020 09:15 AM
Alex_Gole
Hi all,
I am in the process of migrating a Portal to another portal. I am using the clone_item() function to migrate the items unlike this clone users, groups, and content . This works great. The only issue I have is when I try to share items with groups, org or everyone. Although my script does update the sharing for some, I often get this error Item has a Relationship Type that does not allow this. (Error Code: 500)
Any idea what I can do to update sharing for an item and its related items?
Here is my current code:
#source content
source_users = source.users.search('!esri_ & !admin')
#target content
target_users = target.users.search('!esri_ & !admin & !system_publisher')
#source groups
source_groups = source.groups.search("!owner:esri_* & !Basemaps")
#target groups
target_groups = target.groups.search("!owner:esri_* & !Basemaps")
for user in source_users:
    if user.username == "ITPublisher1":
        tester_content = source.content.search("owner:"+ user.username, max_items=500)
        for item in tester_content:
            print(item.access)
            if item.access == "shared":
                for group in source_groups:
                    for group_item in group.content():
                        if group_item.itemid == item.itemid:
                            print(group)
                            target_group = target.groups.search(group.title)
                            for tg in target_group:
                                target_item = target.content.search(item.title)
                                print(tg.groupid)
                                for ti in target_item:
                                    print(ti)
                                    ti.share(everyone=False, org=False, groups=tg.groupid)
                        else:
                            print("not in target portal ")
            #elif item.access == "public":
            #    target_item = target.content.search(item.title)
            #    for ti in target_item:
            #        print(ti)
            #        ti.share(everyone=True, org=False)
            elif item.access == "org":
                    print(ti)
                    ti.share(everyone=False, org=True)
MehdiPira1
Hi @Alex_Gole ,
One of the requirements of cloning is establishing the same relationship between source and target items.
The following link provides a useful step by step process of establishing relationships when cloning (section: Establish relationship between items);
https://developers.arcgis.com/python/sample-notebooks/clone-portal-users-groups-and-content/#establi...
MehdiPira1
Hi @Alex_Gole ,
Alex_Gole
Doesn't clone_items(). Take care of the relationship. In the demo you point to, I notice that they dont use clone_items() when they copy  the items. they use:
what i use:
cloned_items = target.content.clone_items(items=[item], folder=f['title'], copy_data=False, group_mapping)
what is used by the sample:
 target_item = target.content.add(item_properties, data_file, thumbnail_file,
                                             metadata_file, source_item.owner, folder_name)
 It looked like the relationship between items was taken care of by clone_items().
MehdiPira1
@Alex_Gole
No it doesn't.
These are the steps required for items to be cloned properly:
Items
Copying items consists of multiple steps as explained in the following section of the sample:
  1. For each user create a mapping of itemId to the Item
  2. Prepare sharing information for each item
    Print a mapping of item and its group membership
  3. Copy items one by one
  4. Establish relationship between items
Alex_Gole
OK thanks!
