Road Sign Extraction with Deep Learning Example?
3920
10-07-2020 10:36 AM
COSPNWGuy
Hi all. I attended the imagery summit yesterday and saw the example of extracting road signs from video using deep learning again. We will be doing a road sign inventory soon and would like to try this workflow. I have seen this showcased several times now in different ESRI presentations\forums. I am wondering if there are any resources for this workflow, particularly any training datasets and recommendations for equipment and capture specs? The closest thing I could find is Automate Road Surface Investigation Using Deep Learning example which I'm sure is similar. Thanks again.
DanPatterson
MVP Esteemed Contributor
The source and its data is on their github site
arcgis-python-api/samples/04_gis_analysts_data_scientists at master · Esri/arcgis-python-api · GitHu...
... sort of retired...
COSPNWGuy
Not seeing anything for road signs or data?
DanPatterson
there is a data folder but not anything specific to road signs, that is just where the notebooks and the data are housed
GitHub - Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python
check inside the Samples folder for other bits
MehdiPira1
LukeHenderson1
Is there anything new with this? Gathering GIS data for DOT assets from cameras would be beneficial project.
