Installing ArcGIS python package using pip breaks pip/virtual env
8280
12
04-06-2022 09:10 AM
CParker
I am attempting to install ArcGIS python package in a clean virtual env. I'm running Python 3.10.4 currently. After running 'pip install arcgis' it looks like it installs correctly, but then nothing works. I cant run a script in that virtual env, I cant run any pip commands. The only option has been to delete the virtual env.
Example errors after install, was running pip freeze:
  File "C:\Users\XXXX\AppData\Local\Programs\Python\Python310\lib\importlib\_common.py", line 89, in _tempfile
    os.write(fd, reader())
  File "C:\Users\XXXXX\AppData\Local\Programs\Python\Python310\lib\importlib\abc.py", line 371, in read_bytes
    with self.open('rb') as strm:
  File "C:\Users\XXXXX\AppData\Local\Programs\Python\Python310\lib\importlib\_adapters.py", line 54, in open
    raise ValueError()
ValueError
I have also tried installing arcgis with no dependencies and then installing the bare minimum, but then python complains that modules are missing and wont run a script with a arcgis import.
Any help would be greatly appreciated.
Tags (3)
DanPatterson
MVP Esteemed Contributor
Were you following the links in the "What's Included" section of the following link for installations instructions for your appropriate environment?
Esri/arcgis-python-api: Documentation and samples for ArcGIS API for Python (github.com)
... sort of retired...
CParker
I was not. Since its hosted on PyPi I was just trying to install it via pip. I am not a fan of conda/anaconda. I literally just want to 'pip install arcgis' like it is listed on PyPi:
https://pypi.org/project/arcgis/
CParker
you all can ignore this question. I found how to do what I need with a pure REST api call with python requests. (calling a feature server)
I will say, something IS broken with arcgis python package. Having a package on PyPi that cannot be installed properly is not right...
JDR302Dev
Can you please share how you did that???
JosephRathvon
I am having the same issue. I installed using pip because conda/anaconda keeps messing up my flask site.  I tried to workaround with Requests but only got most of my site working.  Trying to fill in the gaps and installed arcgis.   now I get the same error.
CParker
Well good luck buddy, I get the sense they don't want us using just pip for some reason... What functionality are you missing with Requests, if you don't mind me asking?
JosephRathvon
I need to updatefeatures in an AGOL feature service. I keep getting a bad token response to my POST request.
CParker
Have you reviewed the different Auth methods to do something similar in Requests?
https://developers.arcgis.com/documentation/mapping-apis-and-services/security/#api-keys
JosephRathvon
Thanks. I'll take a look at that. I need to unbrick my python install first though.
