How to Resolve Single Shot Detector(SSD) issues
4947
8
03-07-2020 10:48 PM
ManojG
I am new to Deep Learning and arcgis.learn module. I am following the case study "Palm Tree Detection" . While Running the code the below Error is occurring. How can I Resolve this Issue?
arcgis.learn object detection‌deep_learning arcgis-api-python palm tree-detection‌
ssd‌ single-shot-detector‌ #fastai
DavidPike
MVP Notable Contributor
From a purely python perspective it's not understanding your class name 'models'.
Try pytorch.models.resnet34 or whatever module you imported.
ManojG
Thank you David.
But I Just imported SingleShotDetector function from arcgis.learn. Which is having the modules from pytorch, fastai and scikit-image
DavidPike
If it's just being passed as a parameter, try = 'RESNET34'
ManojG
I tried this as you suggested. But the Errors raised at the time of importing packages. so I Undo the changes
DanPatterson_Retired
Did you set up your environment properly?
Use Deep Learning to Assess Palm Tree Health | Learn ArcGIS
There are issues if you don't have the correct versions set up
For example
Deep Learning to Assess Palm Tree Health: .emd file error
Deep Learning to Assess Palm Tree - prepare_data problem
plus many more.
You might want to look at their github site for various examples and check to see if anything there helps
arcgis-python-api/samples/04_gis_analysts_data_scientists at master · Esri/arcgis-python-api · GitHu...
ManojG
I am following the link(https://learn.arcgis.com/en/projects/use-deep-learning-to-assess-palm-tree-health/) from first onwards.
I removed the palm-detection environment.
again created the environment and same packages installed.
This time the error happening in preparedata.
The ArcGIS pro is 2.5 version
Arcgis Python api is 1.7.0 version
the H/W is intel  i7-8th generation with NVIDIA GeForce GT 730(Desktop)
The process is in Deadlock.
One thing I really didn't get.
I already ran this case study in my laptop (i7-8th generation and switchable graphics[AMD Radeon]) with 20 epochs.
It ran smoothly. Now I would like to increase the number of epochs to 50. This will take much time to complete the training. So, this time I go with Desktop. Nothing Changed in the process of execution. But the errors are occurring about the Package installations.
How can I resolve this issue?
Are there any Hardware Setting changes needed?
Contact the people that wrote the lesson (If they are listed) or tech support, there seems to be a lot of fiddly stuff with those deep learning and related modules
by Anonymous User
Not applicable
Manoj have you installed the required dependencies for arcgis.learn. Can you paste the output of command "conda list" here.
