How to get variables into Python code block of arcpy.management.CalculateField
2548
12-01-2022 06:02 AM
TomGeo
I have one calculation where it works great getting a variable in:
arcpy.management.CalculateField(sector_angle, 'Buffer', "getBuffer(!Area!)", "PYTHON3",
                                f"""def getBuffer(area):
                                    if area < {median_area}:
                                            return 1
                                    if area > {median_area}:
                                            return 2""",
                                "TEXT", "NO_ENFORCE_DOMAINS")
And I have another calculation on the same feature class where it does not work.
arcpy.management.CalculateField(sector_angle, 'Buffer_Radius', "setDistance(!Buffer!)", "PYTHON3",
                                f"""def setDistance(buffer):
                                    if buffer == 1:
                                            return {pnt[2]}
                                    elif buffer == 2:
                                            return {pnt[3]}""", "FLOAT")
Some example on how the variables look:
pnt[2] = 2043.8900146484375
pnt[3] = 4087.780029296875
The type of both variables is float, but the resulting 'Buffer_Radius' field contains only NaN.
I tried all sorts of stuff on how to get the variables into the code block, but while it was so easy in the first function, I don't have luck with the second one. How do I get my variables into the 'Buffer_radius' field?
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
DanPatterson
MVP Esteemed Contributor
pnt[2]
can't be a variable it is a slice of pnt, so where is pnt defined? and maybe if it is somewhere try
p2 = pnt[2]
p3 = pnt[3]
assuming of course that the values are slices of pnt
... sort of retired...
RogerDunnGIS
I think it has to do with the properties of the buffer_radius field.  Maybe there's something amiss with regards to scale and precision that won't let numbers like 2043.8900146484375 and 4087.780029296875 fit inside it.  Or, if buffer_radius is a text field, maybe it's not long enough.  What can you tell us about that field?
DavidAnderson_1701
Throwing a few thoughts out here.  How about using a lambda function?  Also I wonder about the use of the {}.  In't that the syntax for defining a dictionary?  I think the NAN might be because the return value is a NULL dictionary.
DanPatterson
{} is also used in python format strings.
median_area = 5
area = 2
func = f"""
        return 1
        return 2
print(func)
    if area < 5:
        return 1
     if area > 5:
        return 2
TomGeo
Thanks for all the valuable thoughts and inputs. In the end, since I had all the logic anyway in Python, I ended up using an update cursor. Time wise, it is almost the same if I run those two CalculateField runs, slightly slower...
I tried the whole thing of course straight in ArcGIS Pro and there my code block works. However, I think @RogerDunnGIS has a fair point talking about the format of fields. The first CalculateField run is creating the buffer field, as 'TEXT'! But my second CalculateField run is using integers in the if-statement...
I haven't had time to try it, but 1 should not be '1', and thereby the error source is once more found about 40 cm in front of the screen. 😅
