'error': {'code': 498, 'message': 'Invalid Token'
31675
15
12-07-2020 03:34 AM
Clive_S
I used the ESRI Python token code sample, which returns a token.
However when I use the token in <url+token>, I get an error??
formatted_json = [feature['attributes'] for feature in raw_json['features']]
KeyError: 'features'
{'error': {'code': 498, 'message': 'Invalid Token', 'details': []}}
The code is:
ef get_token():
    params = {'username': username, 'password': password, 'expiration': str(60), 'client': 'referer', 'referer': referer, 'grant_type': 'client_credentials', 'client_id': client_id, 'client_secret': client_secret,   'f': 'json'}
    request = requests.get(token_url, params=params)
    response = request.json()
    #print(response)
    token = response['access_token']
    return token
portalToken = get_token()
#### THIS works + returns Token
#print(portalToken)
##print("END")
if __name__ == "__get_token__":
    """optional location for parameters"""
    print(sys.argv[0])
 The get_token returns a token.. they all seem to have .. at the end of the token?? This is really frustrating, would appreciate any pointers!!
Clive
Tags (3)
DavidPike
MVP Notable Contributor
OK.
Assuming username, password and url parameters are correct, your request seems to be missing headers - headers = {'content-type': 'application/x-www-form-urlencoded'}
are you passing the url as url = portalUrl + '/sharing/rest/generateToken?'
Also can't see the parameters of clientid secret and granttype.
import requests
portalUrl = "https://domain/portal"
username = 'username'
password = "password"
def generateToken(username, password, portalUrl):
    # Retrieves a token to be used with API requests.
    parameters = {'username': username,
                  'referer': portalUrl,
                  'expiration': 60,
                  'f': 'json'}
    response = requests.post(url, data=parameters, headers=headers)
    try:
        jsonResponse = response.json()
        if 'token' in jsonResponse:
            return jsonResponse['token']
        elif 'error' in jsonResponse:
            print (jsonResponse['error']['message'])
            for detail in jsonResponse['error']['details']:
                print (detail)
    except ValueError:
        print('An unspecified error occurred.')
        print(ValueError)
token = generateToken(username, password, portalUrl)
Clive_S
I changed
 the get to post, still getting invalid token error.
to
request = requests.post(token_url, params=params)
DavidPike
what does the query url look like with the token appended? do you have:
"&token=" + token
request.get(https://blablabla?f=json&token=hfwjfjkewkjfwkfjk..
Clive_S
Hi David,
Thanks for the reply.
I updated the code, got a more useful error.... I think??
def get_token(url, username, password):
    ''' use this to get a token from arcgis online '''
    gen_token_url = token_url
    # payload params for the post request
    params = {'username':username, 'password':password,'client':'referer', 'referer':url, 'client_id': client_id, 'client_secret': client_secret, 'grant_type': grant_type, 'expiration':expiration, 'f':'json'}
    response = requests.post(gen_token_url, data=params, verify=False)
    data = response.json() # convert to json
    print('access_token')
    #return data['access_token']
mytoken = get_token(url, username, password)
    print(sys.argv[0])
I added: client_id, 'client_secret': client_secret, 'grant_type': grant_type
Now I am getting  a new error: InsecureRequestWarning: Unverified HTTPS request.
redirect_uri not specified
I don't want users to login!!  I want to get a token to login
DavidPike
Yep, again, what is the request you're attempting?
Clive_S
Hi David.
I need to automate getting the Token.
The previous code returned a Token, but threw an invalid Token error consuming the REST end point (json = URL+Token).
I have a rest endpoint and URL.
If I go to  'https://mycomp.maps.arcgis.com/sharing/rest/oauth2/token', this provides a Token
Then if I use: json_file = url+token, this returns JSON.
Is this clearer??
DavidPike
what i mean is that since the issue seems to be the format of the post or get to your rest endpoint, it would be helpful to share what it looks like.
Clive_S
Hi David,
In the code:
#def get_token(url, username, password):
def get_token():
mytoken = get_token()
print(get_token) <<<  warning
The warning is:
The error/warnig:
C:\Users\user\anaconda3\python.exe C:/Users/user/PycharmProjects/pythonProject1/Test.py
C:\Users\user\anaconda3\lib\site-packages\urllib3\connectionpool.py:979: InsecureRequestWarning: Unverified HTTPS request is being made to host 'eiffagekier.maps.arcgis.com'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
  warnings.warn(
Clive_S
Hi David,
I thought that stated at the beginning of the post that if I create a Token using the Portal Form.GenerateToken.PNG
 Then use that token in the REST url.
json_file = url+token, this returns the JSON. The issue that I have is trying to generate a Token.
This returns the error message/s.
DavidPike
OK.
import requests
                  'expiration': 60,
                  'f': 'json'}
    try:
                print (detail)
    except ValueError:
        print(ValueError)
