Deep Learning prepare_data
5704
10
11-25-2019 10:54 AM
LaurynasGedminas2
Hello,
I am following the example here for pixel classification:
Pixel-based Classification Workflow with | ArcGIS for Developers
In my case I am exporting data and labels from ArcPro, when i run:
data = prepare_data(data_path, batch_size=16)
I get error:
TypeError: int() argument must be a string, a bytes-like object or a number, not 'NoneType'''
What is the parameter settings needed in ArcPro to export data for this example?
API version: 1.7.0
ArcGIS Pro 2.4
Thank you,
Tags (1)
LaurynasGedminas2
If i export data as 'labelled tiles' i get error:
lib\site-packages\arcgis\learn\_data.py in prepare_data(path, class_mapping, chip_size, val_split_pct, batch_size, transforms, collate_fn, seed, dataset_type, resize_to, **kwargs)    357     358     if dataset_type is None and not has_esri_files:--> 359         raise Exception("Could not infer dataset type.")    360     361     if dataset_type != "Imagenet" and has_esri_files:Exception: Could not infer dataset type.
by Anonymous User
Not applicable
Try specifying the dataset_type. So for Classification tiles, add dataset_type='Classified_Tiles' to call the prepare_data function.
LaurynasGedminas2
when i try to export  'Classified Tiles' thru export tool it gives error: ERROR 002091  Parameters are inconsistent.
by Anonymous User
Not applicable
Can you post a screenshot of parameters you have supplied to the tool.
LaurynasGedminas2
this gives the ERROR 002091  Parameters are inconsistent.
it's 3 band raster, TIFF or PNG still the same, sites were produced by the Training Sample Manager:
by Anonymous User
Not applicable
Can you check if there is any missing values in the ClassValue column .
stephenescarzaga
I just went through this problem. Documentation says that exporting "classified_tiles" requires a classified raster (thematic) instead of feature class. So I had to do polygon to raster, then 'set raster properties'. Once I did that It let me export. Not sure if this is the correct way.
EDIT: looking at the 'extract building foot prints' here, my workflow with ultimately not work. I'm trying to prepare the data now for training and I'm getting errors.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Laurynas Gedminas Try to follow the methodology documented in this link to export training data for classified tiles here Extracting Building Footprints From Drone Data | ArcGIS for Developers .
