clone_items() Behavior has changed
7582
10
03-28-2023 02:18 AM
JoeNunn
Hi, I have previously succeeded in running a python script (set up as a tool in ArcGIS pro) that cloned an app (in this case the attachment viewer) and all  it content which was a map and the layers within the map. It previously functioned perfectly, however a change (earlier this year) has occurred where all the items are cloned (inc a new set of layers), however the layers in the map are still pointing back to the original layers.  A diagram below explains:
Current template:   Orig App >Orig Map >Orig Layers
What should happen after cloning: New App  > New Map > New Layers
What happens after cloning: New App  > New Map > Orig Layers
The line of script looks like this:
appToClone = gis.content.get('xxxxxxxxxxxxxxxxxxxxx')
layerList = [appToClone]
clonedLyrs = gis.content.clone_items(layerList, folder=folderName, copy_data=False, search_existing_items=False)
Any ideas why this is occurring?
Many thanks
Joe
kapalczynski
I dont understand... How are you publishing Feature Layers, Web Maps and Experience from AGOL to Portal?
If I use the clone I get all 3 to go over and the feature layer seems to be ok but the web map is referencing AGOL rather than portal.
