Can't open spatial dataframe in Spyder 4.2.1 Variable Explorer - not picklable
5030
6
02-24-2021 01:26 PM
Zeke
Regular Contributor III
I upgraded to Spyder 4.2.1 from 3.6, and now when I run my script that creates a spatially enabled dataframe, the dataframe 'sdf' won't open in Variable Explorer. Instead it gives a message stating 'The variable is not picklable'. The console pane shows a long traceback ending in '
_pickle.PicklingError: Can't pickle 'geoprocessing server result object' object: <geoprocessing server result object object at 0x000001F686A82A80>'.
This was working before the upgrade, and I'm thinking after it for a while as well (might be wrong there). running things like sdf.head() works fine. Code below.
Running Python 3.7.9 64-bit | Qt 5.9.6 | PyQt 5.9.2 | Windows 10 | Spyder 4.2.1
import time as t
import os
import sys
import pandas as pd
import arcpy
from arcpy import env
from arcgis.features import GeoAccessor, GeoSeriesAccessor
gdb = r"C:\Users\Owner\Desktop\Tract_Aggregation\Tract_aggregation.gdb"
fds = 'Detroit_tracts'
# fc = 'All_Detroit_Tracts_TL_Data_lt_4200'
fc = 'Tract_Agg_1_021621_New'
census_tracts = os.path.join(gdb, fds, fc)
mem_tracts = arcpy.management.MakeFeatureLayer(census_tracts, r"memory\tracts")
env.overwriteOutput = True
env.workspace = os.path.join(gdb, fds)
cutoff = 4200
used_gids = []
def create_sdf():
    Returns
    df : Pandas Dataframe
        Census tracts.
    print('\tCreating Spatial DataFrame...')
    drop_flds = ['OBJECTID',
                 'objectid_1',
                 'object_id']
    try:
        df = pd.DataFrame.spatial.from_featureclass(mem_tracts)
        df.dropna(subset=['geoid'], inplace=True)
        df.drop(drop_flds, axis=1, inplace=True)
        df['under125pe'] = df['under125pe'] * 1.0
        df['under200pe'] = df['under200pe'] * 1.0
        df['under125pe'].fillna(0.0)
        df['under200pe'].fillna(0.0)
        df.set_index('geoid', inplace=True, drop=False)
        df.rename_axis('gid', inplace=True)
        df.sort_values(by='total_hh', axis=0,
                       ascending=False, inplace=True)
        print('\tSpatial DataFrame created\n')
        return df
    except Exception as e:
        print(sys.exc_value)
DanPatterson
MVP Esteemed Contributor
was the arcgis module updated during the process?  Lots of Issues on their github site with the transition from 1.8.2 to 1.8.3 to 1.8.4
... sort of retired...
DanPatterson
What version of arcgis?
There were recent issues with pandas dataframes
Spatially Enabled Data Frame not working with pandas datetime · Issue #874 · Esri/arcgis-python-api ...
and
conda upgrade --no-pin arcgis
this was the solution
Not a spyder issue that I could find on their Issues link
Issues · spyder-ide/spyder (github.com)
Zeke
Thanks @DanPatterson. Using ArcGIS Pro 2.7.1, cloned Python environment from ArcGIS default to which I've added Spyder.
Default Spyder install via this method is Spyder 3.6. This runs but does nothing when I try to view the spatial dataframe in Variable Explorer. Upgrading Spyder to 4.2.1 also runs, but gives error message the pickling error message in original post. Using the upgrade arcgis method you posted tells me that it's already installed. This is really baffling me. Thanks!
DanPatterson
I suspect you won't be able to since it isn't a true Pandas df.  I doubt the spyder crew will have much interest in providing support unless there is a widespread need.  Numpy and Pandas work fine
Zeke
Thanks @DanPatterson. Maybe so, but prior to a few days ago it would display it. Oh well.
DanPatterson
Zeke
That may be it. I did get the latest (afaik) arcgis module.
