arcpy.CreateAddressLocator_geocoding raise ERROR 000046 too many reference data tables for this style
1368
09-19-2019 07:03 AM
MaximeDemers
I have an error while trying to automatize the creation of an address locator. Any idea what can be wrong in my code below?
I only use 1 data table as reference so why this error?
I am using arcpy v10.6
import arcpy
arcpy.env.workspace = "C:\\Script\\Connexions\\connection.sde\\MyDataSet"
configs = {
    "IN_ADDRESS_LOCATOR_STYLE": "General-Single Field",
    "IN_REFERENCE_DATA": "ReferenceDataFC 'Primary Table'",
    "IN_FIELD_MAP": "'Feature ID' ObjectID VISIBLE NONE;'*KeyField' addresse VISIBLE NONE",
    "OUT_ADDRESS_LOCATOR": "C:\\Script\\Output\\MyLocator",
    "CONFIG_KEYWORD": None
    "ENABLE_SUGGESTIONS": "ENABLED"
arcpy.CreateAddressLocator_geocoding(
    in_address_locator_style = configs["IN_ADDRESS_LOCATOR_STYLE"],
    in_reference_data = configs["IN_REFERENCE_DATA"],
    in_field_map = configs["IN_FIELD_MAP"],
    out_address_locator = configs["LOC"],
    config_keyword = configs["CONFIG_KEYWORD"],
    enable_suggestions = configs["ENABLE_SUGGESTIONS"]
I have noticed that if I write "General - Single Field" instead of "General-Single Field" for the in_address_locator_style parameter I got the ERROR 000039: Not enough reference data tables for this style.
This is very confusing...
MaximeDemers
After many test, I have found that in_address_locator_style parameter should be written "General - Single Field" and the in_reference_data parameter should only have the featureClass full path (or name if the arcpy.env.workspace is defined correctly like below)
import arcpy
configs = {
    "IN_ADDRESS_LOCATOR_STYLE": "General - Single Field",
    "IN_REFERENCE_DATA": "ReferenceDataFC",
MaximeDemers
import arcpy
configs = {
