ArcGIS API for Python Ideas
Other Boards in This Place
NOTE: ArcGIS API for Python ideas require a label. See the descriptions to choose the label that best aligns with your idea submission.
Latest Activity (62 Idea Submissions)
Sort/Filter :
Open
My organization is attempting to create an automated process using the API for Python to check items in our organizat...
ColinBergmann_ct
by ColinBergmann_ct Occasional Contributor
in ArcGIS API for Python Ideas Last Updated 2 weeks ago
5 0
Open
See question posted here: Does the python Suvey 123 api support creating a n... - Esri Community
ashcom
by ashcom Emerging Contributor
in ArcGIS API for Python Ideas Last Updated 05-25-2026
1 0
Open
Since the Februari 2026 update of ArcGIS Online, using gis.admin is no longer possible using an API key in ArcGIS Onl...
TjibbeWubbels
by TjibbeWubbels Regular Contributor
in ArcGIS API for Python Ideas Last Updated 04-28-2026
3 0
Open
If you provide the group.remove_users() Fuction a list with 25 or more users, the function will fail with the followi...
MarcelBeckmann
by MarcelBeckmann Frequent Contributor
in ArcGIS API for Python Ideas Last Updated 12-01-2025
2 0
Open
It would be useful for geoprocessing tools executed in ArcGIS Enterprise—especially when triggered from Experience Bu...
SimonP
by SimonP Occasional Contributor
in ArcGIS API for Python Ideas Last Updated 11-25-2025
1 0
Open
When cloning webmaps from one portal to another, it is possible to provide a lookup dictionary with {source_item_id :...
MarcelBeckmann
in ArcGIS API for Python Ideas Last Updated 08-11-2025
2 0
Open
Attempting to clone content between ArcGIS Enterprise deployments when authenticated using oauth 2.0 (using the clien...
TraeTimmerman
by TraeTimmerman Occasional Contributor
in ArcGIS API for Python Ideas Last Updated 07-16-2025
2 0
Closed
Credentials for user accounts are stored in Azure Keyvault and are accessed during runtime using. There is need to se...
VidyaSagarGurung
by VidyaSagarGurung Emerging Contributor
in ArcGIS API for Python Ideas Last Updated 07-03-2025
1 1
Open
Adding an image to a StoryMap Briefing using the GUI automatically fits the image to the size of the Block. After add...
ATFerguson
by ATFerguson Regular Contributor
in ArcGIS API for Python Ideas Last Updated 06-27-2025
0 0
Open
Hi,Please adjust the item_id parameter of the arcgis.gis.server.Server.publish_sd function to support a dictionary of...
PatriceLabbé
by PatriceLabbé Frequent Contributor
in ArcGIS API for Python Ideas Last Updated 05-16-2025
2 0
Open
Currently, if you read the configuration JSON for a web map (specifically looking at each layer within it's operation...
MikeLachance1
by MikeLachance1 Regular Contributor
in ArcGIS API for Python Ideas Last Updated 04-15-2025
3 0
Open
Please update the API to enable adding all Layers and Tables at once.As of the ArcGIS API for Python version 2.4.0 an...
Clubdebambos
by Clubdebambos MVP Regular Contributor MVP Regular Contributor
in ArcGIS API for Python Ideas Last Updated 03-31-2025
0 0
Open
The extract_changes function of a FeatureLayerCollection in the Esri Python API (arcgis python library) does not have...
GFlonk
by GFlonk Occasional Contributor
in ArcGIS API for Python Ideas Last Updated 11-03-2025
1 1
Open
When exporting data to a particular format, provide methods that enable users to check what potential limitations may...
PeterKnoop
by PeterKnoop MVP Regular Contributor MVP Regular Contributor
in ArcGIS API for Python Ideas Last Updated 04-18-2025
1 2
Open
Greetings,GeoAccessor.to_featureclass(location, overwrite=True, has_z=None, has_m=None, sanitize_columns=True) is qui...
TylerT
by TylerT Frequent Contributor
in ArcGIS API for Python Ideas Last Updated 03-21-2025
1 1
238 Subscribers
Idea Submission Guidelines
We love hearing from you about how to improve our products. To learn how to submit a valid idea, please review the Submission Guidelines
Top Kudoed Ideas (last 30 days)
Top Kudoed Authors
