ArcGIS API for JavaScript 4.18 transparency issue when scrolling
1435
02-15-2021 08:57 PM
ChrisCable
When scrolling a map layer in 4.18 that has a transparency value set, the view draws over any cached areas resulting in the layer briefly appearing as if no transparency is set, then fading to the correct transparent appearance. The resulting "pulsing" of the layer is unacceptable. This behavior is new to 4.18.
I have created a demo here: https://mapping.northernbeaches.nsw.gov.au/test.html
Scroll around and you will see what I mean. Any advice is appreciated.
UndralBatsukh
Hi there,
This issue will be fixed at 4.19. You can already test the fix using our `next` version. You can use this test app to see the fix. Please let me know if you run into issues.
-Undral
UndralBatsukh
Hi there,
I can reproduce the issue and created an issue for it. I will update you here as soon as we get it fixed.
-Undral
UndralBatsukh
Hi there,
-Undral
